When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
$(document).click(function(e) { // ####Check for left button if (e.button == 0) { // alert('clicked'); console.log('page......clicking'); checkhitrate('ads_hitrate');//check the document.activeElememnt source such as ifram or <a> tag }else {}});it works but can not detect mouse right click or mouse left click;so try to other code such as followsvar mouseleft=null;document.addEventListener('mousedown', function(event) { switch (event.button) { case 0: mouseleft=1; checkhitrate('ads_hitrate'); console.log('mouse Left button clicked.'); break; case 1: mouseleft=0; console.log('mouse Middle button clicked.'); break; case 2: mouseleft=0; console.log('mouse Right button clicked.'); break; case 3: mouseleft=0; console.log('mouse Browser Back button clicked.'); break; case 4: console.log('Browser Forward button clicked.'); break; default: console.log('Unknown button clicked.'); }});*/it is working ok, but not work if the content area with iframe...so we need use blur as followswindow.addEventListener('blur', notFocused);function notFocused() { localStorage.setItem('focus','0');setTimeout(()=>{$(window).focus();},200);checkhitrate('ads_hitrate');console.log('NOT focused',ia2++);return 0;}and check whether visitor leave current page to forward to other site, use this function becoz we can not idenity it is right or left click.if .onbeforeunload even is triggered it mean it is from left clickwindow.onbeforeunload=function(e){ console.log('hist-onbeforeunload'); localStorage.removeItem("stateHistoryonbeforeunload"); localStorage.setItem("stateHistoryonbeforeunload", 1);}event onbeforeunload should be earlier than checkrate();function checkhitrate(hitrate){ if (hitrate=='ads_hitrate')sendclick();}function sendclick(){if (document.activeElement.src) var tmp=document.activeElement.src ; else tmp=""if (document.activeElement.tagName === "IFRAME"){if (tmp.indexOf('client=ca-pub-')>0){setTimeout(()=>{console.log('notfocused _post3',"stateHistoryonbeforeunload",localStorage.getItem("stateHistoryonbeforeunload"));document.activeElement.blur(); if (localStorage.getItem("stateHistoryonbeforeunload")=="1"){_post3(url,JSON.stringify(obj),fun);localStorage.removeItem("stateHistoryonbeforeunload")}},200);}}Note: every click then clear last document.activeElement by document.activeElement.blur() so next check click will be working again
During driving traffice to my website, it will create google adsense invalid impression or not ?
Asked by Wilson Edwards
at 2025-06-27 11:02:02
Point:500 Replies:0 POST_ID:829368USER_ID:12108
googleads;invalid traffic
I read some outside third-party company to prompt driving web traffic to my website to increase my google adsense revenue.
How are they able to do ?
During driving traffice to my website, it will create google adsense impression or not ?
Google will treat that impression is invalid ?
