When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Wilson Edwards
at 2025-01-29 21:04:40
Point:500 Replies:4 POST_ID:829293USER_ID:12108
javascript;python3;chrome
Visitors or users may open many page of website to get streaming data ,and they want to open many browser tabs to read different data. That will depend on your Laptop or mobile capiblity how can handle many new socket.io to run on multiple tab at the same time, If limited computer resouce or memory, you will be limited for number of browser tabs display.
If u use socket with Redis /stream event that allow display directly into html page tab (just type https://yourdomain:5051/stream on address bar) or throught javascript parse data into html page but it may only allow 3 tabs running on the same time.
How you can run it on many tabs ?
1-You can use localStorage(getItem or setItem) to share information between browser tab
Or...you can use
2-
window.addEventListener('blur', notstream);
window.addEventListener('focus', stream);
When the user not read or not focus the tag, close the streaming socketio, then When
that users want to read it again and focus the tag, reconnect the socket. We know users only can read 1 tag at a time only,
function notstrem(){
souce.close();//close the socket.io
function stream(){
//user focus the tab again
refresh();// re-run that funation u can stream data before
function refresh(){
//Redis
var source = new EventSource("https://yourdomainsocket-site.com"+":5051/stream");
source.addEventListener('publish', function(event) {
dataextract(event.data);
if (typeof ws=='function')ws(event.data);
if (typeof updatechart=='function')updatechart(event.data);
}, false);
source.addEventListener('error', function(event) {
}, false);
return source;
let source=null;
jQuery(document).ready(function($) {
console.log("onload");
source=refresh();
Author: Wilson Edwards replied at 2025-01-29 21:16:36
Just example code for Event /stream with socket, u can use https://yourdomain:5051/stream or https://yourdomain:5051
var lnk="https://yourdomain.com:5051";
socket = io.connect(lnk, {reconnection:false});
var socket_id=socket.on("connect", ()=>{
socket.emit("join-room", {"room_id":"question"});
socket.on("streamdata", (event)=>{
data_extract(JS(event.data));
Server python3 code
socketio = SocketIO(app,cors_allowed_origins='*')
@socketio.on("connect")
def on_connect():
sid = request.sid
print("---------------------------------")
print("New socket connected ", sid)
@socketio.on("join-room")
def on_join_room(data):
print("-------##############------")
#sid = request.sid
room_id = 'question'
join_room(room_id)
# your socketio.emit() function here
#for example: if use schedule
def server_side_event():
""" Function to publish server side event """
with app.app_context():
try:
arr=get_data()
if len(arr) >0:
sse.publish(arr, type='publish')
socketio.emit("streamdata", {"data":arr},broadcast=True,include_self=True,room="question")
print("Event Scheduled at ",datetime.datetime.now())
except:
pass
sched = BackgroundScheduler(daemon=True)
sched.add_job(server_side_event,'interval',seconds=get_schd_time())
sched.start()
Author: Wilson Edwards replied at 2025-01-28 21:50:56
Using
that may not be better;
try to use classical python socket and javascript socket.io is better, and don't use /stream Event
For example:
var lnk="https://computer28.com:5051";
That u can open many browser tab as u want to get socket data in real-time at the same time
