Asked by test test
at 2026-04-11 08:43:52
Point:500 Replies:4 POST_ID:829378USER_ID:12446
apache;centos7
Author: test test replied at 2026-04-11 09:53:06
httpd 2.4.6 version is centos version, httpd 2.4.34 version is Red hat version
Author: test test replied at 2026-04-11 09:01:33
httpd binary location at/opt/rh/httpd24/root/usr/sbin/httpd, then httpd -v, u can see Aapche/2.4.34 (previous is 2.4.6), higher version, can have HTTP2 function,mod_http2.so could be found at /opt/rh/httpd24/root/etc/httpd/modules
Author: test test replied at 2026-04-11 08:56:49
service httpd24-httpd start
Author: test test replied at 2026-04-11 08:54:17
go to /etc/yum.repos.d, changeasi-fs-s.contabo.net tovault.centos.org inCentOS-Base.repo file
and change toasi-fs-s.contabo.net tomirrors.aliyun.com in ius.repo, now httpd is recoverd but it should not work becoz httpd24 is installed before, some libaray is collapsed. If upgrade version for httpd, it should , yum install httpd24-httpd , instead..its directory is at /opt/rh/httpd24/root/etc/httpd
