Asked by test test
at 2026-04-11 09:56:43
Point:500 Replies:5 POST_ID:829380USER_ID:12446
apache;centos7;
Author: test test replied at 2026-04-13 06:39:12
clean up the site browser data, then run again http://yourdomain.com
Author: test test replied at 2026-04-13 06:37:47
it maybe 2 possiblity
1-Cloudflare or other CDN, already did it
2-If u did run HTTPS before at the same domain, it will automatically forwarding to HTTPS from http on modern browsers. Try to clean up all browswer data, then run http://your domain.com again.If not forwards, put the code below in your .htaccess
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
Expert: Wilson Edwards replied at 2026-04-11 15:44:07
if add froward rewrite in .htaccess file and re-enable cloudflare, it will cause too many redirect on chrome browser so that it helps to prove the forwarding came from cloudflare.
Author: test test replied at 2026-04-11 10:26:27
https://www.google.com/search?q=why+can+not+find+where+code+is+forwarding+http+to+https+in+.htaccess+and+httpd.conf+file+on+centos7&sourceid=chrome&ie=UTF-8
Author: test test replied at 2026-04-11 10:26:03
it may be Load Balancer issue from your VPS server company
If your server is behind a Load Balancer (like AWS ELB) or a CDN (like Cloudflare), the redirect may be configured at that level.
If u paused your cloudflare, but till forwarding, talk to your VPS server company.
If it is not important,
just add this as follows in .htaccess to pass online SEO checker HTTPto HTTPS test
RewriteEngine On
