When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
$(document).click(function(e) { // ####Check for left button if (e.button == 0) { // alert('clicked'); console.log('page......clicking'); checkhitrate('ads_hitrate');//check the document.activeElememnt source such as ifram or <a> tag }else {}});it works but can not detect mouse right click or mouse left click;so try to other code such as followsvar mouseleft=null;document.addEventListener('mousedown', function(event) { switch (event.button) { case 0: mouseleft=1; checkhitrate('ads_hitrate'); console.log('mouse Left button clicked.'); break; case 1: mouseleft=0; console.log('mouse Middle button clicked.'); break; case 2: mouseleft=0; console.log('mouse Right button clicked.'); break; case 3: mouseleft=0; console.log('mouse Browser Back button clicked.'); break; case 4: console.log('Browser Forward button clicked.'); break; default: console.log('Unknown button clicked.'); }});*/it is working ok, but not work if the content area with iframe...so we need use blur as followswindow.addEventListener('blur', notFocused);function notFocused() { localStorage.setItem('focus','0');setTimeout(()=>{$(window).focus();},200);checkhitrate('ads_hitrate');console.log('NOT focused',ia2++);return 0;}and check whether visitor leave current page to forward to other site, use this function becoz we can not idenity it is right or left click.if .onbeforeunload even is triggered it mean it is from left clickwindow.onbeforeunload=function(e){ console.log('hist-onbeforeunload'); localStorage.removeItem("stateHistoryonbeforeunload"); localStorage.setItem("stateHistoryonbeforeunload", 1);}event onbeforeunload should be earlier than checkrate();function checkhitrate(hitrate){ if (hitrate=='ads_hitrate')sendclick();}function sendclick(){if (document.activeElement.src) var tmp=document.activeElement.src ; else tmp=""if (document.activeElement.tagName === "IFRAME"){if (tmp.indexOf('client=ca-pub-')>0){setTimeout(()=>{console.log('notfocused _post3',"stateHistoryonbeforeunload",localStorage.getItem("stateHistoryonbeforeunload"));document.activeElement.blur(); if (localStorage.getItem("stateHistoryonbeforeunload")=="1"){_post3(url,JSON.stringify(obj),fun);localStorage.removeItem("stateHistoryonbeforeunload")}},200);}}Note: every click then clear last document.activeElement by document.activeElement.blur() so next check click will be working again
ollama can NOT be triggered for cronjob, why ?
Asked by Wilson Edwards
at 2025-02-10 21:49:16
Point:500 Replies:4 POST_ID:829336USER_ID:12108
centos; bash
Author: Wilson Edwards replied at 2025-02-10 22:08:57
Script php to trigger ollama by ollama.php
<?php
chdir(dirname(__FILE__));
$str='ollama serve';
exec("ps -aux |grep ollama",$a);
print_r($a);
file_put_contents('ollama.log',$a);
$str2=file_get_contents("ollama.log");
if (strpos($str2,$str)>0)
exec("pkill -f 'ollama serve'");
exec("exec /usr/local/bin/ollama serve > /dev/null 2>&1 & echo $");
if the exe program is not at /usr/bin, #!/bin/bash , may not find it, try run export to see tis
is included for yourPath that is /usr/local/bin/
Cron-job
28 22 * * 1 7 php /home/yourdir/ollama.php
Be Reminded: if pkill can not find the target to kill process, it will be exit not do next command
in the script //exec("exec /usr/local/bin/ollama serve > /dev/null 2>&1 & echo $");
Expert: rcschroeder replied at 2025-02-10 21:51:09
It seems like you're experiencing issues with running `ollama serve` through a cron job on CentOS, but it works fine when run directly from the command line. Let's dive into the possible reasons behind this behavior.
**Why is ollama serve not triggering for cronjob?**
When you run `ollama serve` directly from the command line, it executes in a normal shell environment with the current working directory (CWD) as `/`. However, when you try to run it through a cron job, the CWD might be different.
Here are some possible reasons why this could happen:
1. **Different CWD**: The cron daemon might set a different CWD for your script than what you expect. This can occur if the cron configuration specifies a different home directory or working directory.
2. **No `export PATH`**: When running from the command line, you likely have an `export PATH` statement that sets up your environment. However, cron jobs often run in a detached mode, which might not include this setup.
3. **Script execution context**: Cron jobs typically run with reduced privileges (e.g., without SUID bits) and may not inherit the same environment variables as your normal shell session.
**Common solutions:**
To troubleshoot and resolve the issue:
1. **Use absolute paths**: Instead of relying on `./` or `./path/to/ollama`, use absolute paths to ensure that the script can be executed correctly, regardless of CWD.
2. **Set environment variables**: Add an `export PATH` statement to your cron job configuration file (usually `/etc/cron.d/<your_script>` for system cron jobs) to set up your environment.
3. **Verify SUID bits**: Ensure that the ollama script is not running with SUID bits, as these can affect permission and execution context.
**Example configurations:**
Assuming you're using a system cron configuration file (e.g., `/etc/cron.d/ollama`):
```bash
# Add the following line to your configuration file:
export PATH="/usr/bin:$PATH"
# If ollama serve relies on specific environment variables:
export OLLAMA_DIR=/path/to/ollama
For detached cron jobs, you might need to use a wrapper script that sets up the environment before executing `ollama serve`. An example:
```bash
#!/bin/bash
# Run ollama serve as expected:
ollama serve
Save this wrapper script, make it executable (e.g., `chmod +x /path/to/wrapper`), and update your cron configuration to run the wrapper instead of the original script.
**Additional tips:**
* Double-check your system configuration files for any specific requirements or restrictions related to executing scripts in detached mode.
* Verify that ollama serve is installed, configured, and executable in both scenarios ( CLI and cron job).
If none of these suggestions help resolve the issue, provide more details about your setup, and I'll do my best to assist you further.
```bash
```bash
#!/bin/bash
ollama serve
Expert: rcschroeder replied at 2025-02-10 21:50:45
The `OLLAMA` command!
I'll do my best to help you understand why OLLAMA cannot be triggered by a Cron job.
**Background**
OLLAMA (Online Learning Library for Machine Analysis) is an open-source tool designed to automate machine learning tasks. It's built on top of Apache Airflow and can be run as a standalone CLI application or integrated into other workflows.
**Cron Job limitations**
Cron jobs are scheduled commands that run at specific intervals, typically stored in the system's crontab file (e.g., `/etc/crontab` on CentOS). However, there are some reasons why OLLAMA might not work with a Cron job:
1. **Environment variables**: When running OLLAMA as a standalone CLI command, it inherits the environment from your shell session. If the Cron job runs in a different environment or has limited access to resources, it may not be able to execute OLLAMA correctly.
2. **Resource constraints**: Cron jobs often run with reduced privileges compared to a full shell session. This can limit the availability of system resources (e.g., memory, CPU) that OLLAMA might require to function properly.
3. **Output handling**: When running OLLAMA in a Cron job, the output might not be redirected or captured correctly, which could lead to errors or unexpected behavior.
**Why does OLLAMA serve work?**
When you run `OLLAMA serve` on your CLI console, it's likely that:
1. You have access to sufficient resources and environment variables.
2. The shell session has enough privileges to execute OLLAMA.
3. Output is handled correctly in the interactive session.
**Workarounds**
To get OLLAMA working with a Cron job, consider the following workarounds:
1. **Use `bash` or `sh` as the cron job environment**: Set the `SHELL` variable in the crontab file to `/bin/bash` or `/usr/bin/sh`, which will allow you to run OLLAMA with a full shell session.
2. **Increase resource limits**: Use `ulimit` commands to increase the maximum CPU, memory, or other resources for your Cron job process.
3. **Redirect output and capture logs**: Use tools like `tee` or `logrotate` to capture and manage output from OLLAMA in a Cron job.
Example crontab entries:
```bash
# Increase resource limits (max CPU and memory)
ulimit -c 1024k
# Run OLLAMA with full shell session
SHELL=/bin/bash /usr/local/bin/OLLAMA serve &
# Capture output and log errors to file
>> /var/log/ollama.log 2>&1
Please note that these workarounds may require adjusting the specific configuration of your system, and you should test them thoroughly before using a Cron job for OLLAMA.
If you're still facing issues, feel free to provide more details about your setup, and I'll try to help you troubleshoot!
**Background**
**Workarounds**
```bash
ulimit -c 1024k
Expert: rcschroeder replied at 2025-02-10 21:50:01
When you're able to run `ollama serve` on the CLI console but it fails in a Cron job scheduler, there are several reasons that could be causing this issue. Here are some common problems and solutions:
1. **Shebang line**: Make sure the shebang line (`#!/bin/bash`) is present at the top of your bash script (if you're using one). This tells the system which interpreter to use when running the script.
2. **Path to ollama serve**: Ensure that the path to `ollama serve` is correct in your Cron job. You can do this by adding the full path to the executable, e.g., `/path/to/ollama/serve`.
3. **Permissions**: The user running the Cron job needs to have the necessary permissions to execute the script. Check the file ownership and permissions of the script using `ls -l` and adjust them if needed.
4. **Directory changes**: If your script is changing directories (using `cd`) before running `ollama serve`, make sure the directory exists and the user has write access to it.
5. **Environment variables**: Some Cron jobs might not inherit the environment variables from the parent process. You can use `export` or `setenv` within your script to set any required environment variables.
6. **Command syntax**: Verify that the `ollama serve` command is typed correctly and has no typos in the Cron job configuration.
Here are some additional steps you can take:
* Check the error message: When the Cron job fails, it will display an error message. Look at this message to determine what's going wrong.
* Use `echo`: Before running `ollama serve`, add `echo` statements to verify that the script is executing correctly and that the variables are set as expected.
Here's a basic example of how your Cron job could be configured:
```bash
# Define the job using the cron syntax
0 12 * * * /path/to/your/bash/script.sh
If you want to use `ollama serve` directly in the Cron job, you can use the following:
```bash
0 12 * * * ollama serve
However, this might not work if `ollama serve` requires specific environment variables or dependencies. In that case, consider adding a bash script to set up the environment and then run `ollama serve`.
```bash
0 12 * * * /path/to/your/bash/setup.sh && ollama serve
Replace `/path/to/your/bash/setup.sh` with your actual setup script.
Make sure that all of your scripts and dependencies are correctly configured, and you should be able to run `ollama serve` successfully as a Cron job.
```bash
```bash
```bash
