When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
$(document).click(function(e) { // ####Check for left button if (e.button == 0) { // alert('clicked'); console.log('page......clicking'); checkhitrate('ads_hitrate');//check the document.activeElememnt source such as ifram or <a> tag }else {}});it works but can not detect mouse right click or mouse left click;so try to other code such as followsvar mouseleft=null;document.addEventListener('mousedown', function(event) { switch (event.button) { case 0: mouseleft=1; checkhitrate('ads_hitrate'); console.log('mouse Left button clicked.'); break; case 1: mouseleft=0; console.log('mouse Middle button clicked.'); break; case 2: mouseleft=0; console.log('mouse Right button clicked.'); break; case 3: mouseleft=0; console.log('mouse Browser Back button clicked.'); break; case 4: console.log('Browser Forward button clicked.'); break; default: console.log('Unknown button clicked.'); }});*/it is working ok, but not work if the content area with iframe...so we need use blur as followswindow.addEventListener('blur', notFocused);function notFocused() { localStorage.setItem('focus','0');setTimeout(()=>{$(window).focus();},200);checkhitrate('ads_hitrate');console.log('NOT focused',ia2++);return 0;}and check whether visitor leave current page to forward to other site, use this function becoz we can not idenity it is right or left click.if .onbeforeunload even is triggered it mean it is from left clickwindow.onbeforeunload=function(e){ console.log('hist-onbeforeunload'); localStorage.removeItem("stateHistoryonbeforeunload"); localStorage.setItem("stateHistoryonbeforeunload", 1);}event onbeforeunload should be earlier than checkrate();function checkhitrate(hitrate){ if (hitrate=='ads_hitrate')sendclick();}function sendclick(){if (document.activeElement.src) var tmp=document.activeElement.src ; else tmp=""if (document.activeElement.tagName === "IFRAME"){if (tmp.indexOf('client=ca-pub-')>0){setTimeout(()=>{console.log('notfocused _post3',"stateHistoryonbeforeunload",localStorage.getItem("stateHistoryonbeforeunload"));document.activeElement.blur(); if (localStorage.getItem("stateHistoryonbeforeunload")=="1"){_post3(url,JSON.stringify(obj),fun);localStorage.removeItem("stateHistoryonbeforeunload")}},200);}}Note: every click then clear last document.activeElement by document.activeElement.blur() so next check click will be working again
how to allow python socket streaming data if using cloudflare proxy on my website
Asked by test test
at 2025-03-03 21:46:28
Point:500 Replies:4 POST_ID:829359USER_ID:12424
cloudflare;proxy;socket;python;centos 8;apache
I am using cloudflare to protect my website recently,
but I have a page which is using python socket to send streaming data to visitor with 5000 port
such as http://mywbesite.com:5000.
Before using clouldflare, visitor can get data from port 5000, now after using
cloudflare, all visitors to my website can not get any data from port 5000.
Now I pause cloudflare, the python socket port is working back again..
The question is I would to like to keep all cloudflare service such as proxy but python socket port need to work for exception by cloudflare, how can I do that ?
My Simple python socket code:
from flask import Flask, render_template, request, session,jsonify
from flask_sse import sse
from flask_socketio import SocketIO, emit, join_room
import platform
import logging
from flask_cors import CORS
import socket....
if __name__ == "__main__":
app.run(host="0.0.0.0",debug=False, port=5000, ssl_context=("mycert")
Expert: rcschroeder replied at 2025-03-03 21:49:39
To allow streaming data from your Python socket server to be accessible even when Cloudflare is enabled, you'll need to configure Cloudflare to exempt the specific port range (5000 in this case) and also set up a special URL that bypasses Cloudflare's proxying. Here's a step-by-step guide:
**Cloudflare Configuration:**
1. Log in to your Cloudflare account and navigate to the "Proxy Rules" section.
2. Click on "Create Rule" and select "HTTP request headers, URLs, or IP addresses."
3. Name this rule something like "Allow streaming data on port 5000." (e.g., "Streaming Data Exemption")
4. In the "Match any of the following" field, enter `http://mywebsite.com:5000`. You can also use a regex pattern if needed.
5. In the "Request headers, URLs, or IP addresses to block" field, leave it blank.
6. Click "Save changes."
However, this will only exempt direct requests from Cloudflare's proxy rules. To allow your Python socket server to be accessible even when Cloudflare is enabled, you'll need to set up a special URL that bypasses the proxy.
**Bypassing Cloudflare Proxy with a Custom URL**
1. Create a new page on your website (e.g., `https://mywebsite.com/stream`) that will serve as the "bypass" URL for your Python socket server.
2. In this new page, include a meta tag that tells Cloudflare to bypass its proxy rules:
```html
<meta http-equiv="X-Frame-Options" content="SAMEORIGIN">
<meta http-equiv="Cache-Control" content="no-cache, no-store, must-revalidate">
<meta http-equiv="Pragma" content="no-cache">
<meta name="robots" content="noindex, nofollow">
3. In your Python socket server code, use the `getsockname()` method to get the address of your listening socket and then serve this address from your "bypass" URL:
```python
import socket
def stream_data():
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.bind(("0.0.0.0", 5000))
s.listen(1)
while True:
conn, addr = s.accept()
# Serve data here...
pass
4. In your "bypass" URL page, use the `getsockname()` method to get the address of your listening socket and serve it directly:
```html
<% if request.method == 'GET' %>
<script>
var addr = '<%= s.getsockname()[0] %>:5000';
window.location.href = 'http://' + addr;
</script>
<% endif %>
Note: The above code snippet is a simplification, and you should adapt it to your specific use case.
**Apache Configuration (optional)**
If you're using Apache as your web server, you can set up a custom URL to bypass Cloudflare's proxy rules. Create an `.htaccess` file in the same directory as your "bypass" page:
```bash
# Custom URL to bypass Cloudflare proxy
RewriteRule ^/stream$ http://localhost:5000 [L,R=301]
This will rewrite any request to `/stream` to `http://localhost:5000`, allowing your Python socket server to be accessible even when Cloudflare is enabled.
**Testing**
1. Verify that your "bypass" URL is working correctly by visiting it in a browser.
2. Use tools like Wireshark or Fiddler to inspect network traffic and ensure that data is being sent from the `http://mywebsite.com:5000` port when accessing the "bypass" URL.
By following these steps, you should be able to allow streaming data from your Python socket server to be accessible even when Cloudflare's proxy is enabled.
```html
```python
import socket
def stream_data():
s.listen(1)
while True:
pass
```html
<script>
</script>
<% endif %>
```bash
**Testing**
Expert: rcschroeder replied at 2025-03-03 12:40:43
The issue you're facing is due to Cloudflare's proxying behavior, which blocks incoming connections on ports below 1024 by default. This is a security feature to prevent unauthorized access to your server.
To allow your Python socket streaming data to work while still using Cloudflare's proxying service, you have a few options:
1. **Use a non-standard port above 1024**: Modify your `app.run()` line to use a custom port number above 1024. For example:
```python
app.run(host="0.0.0.0", debug=False, port=8080, ssl_context=("mycert"
Then, in your Cloudflare settings, you can specify a custom proxy port that points to your server's `localhost:8080`. This way, incoming requests on the specified port will be proxied through your server.
2. **Use Cloudflare's "Proxied" setting**: In Cloudflare's proxy settings, you can select the option for the specific domain or subdomain to use a custom proxy port. Go to Cloudflare > Proxies > Custom Proxied Ports and add your custom port number there.
3. **Configure Cloudflare's proxy rules**: You can also configure Cloudflare to allow specific IP addresses or domains to bypass the proxying behavior on certain ports. To do this, go to Cloudflare > Rules > Custom SSL/TLS Settings and create a new rule that specifies the IP address or domain you want to allow.
4. **Use a reverse proxy server**: Set up a reverse proxy server in front of your Python application, which will sit between your server and Cloudflare's proxy. This way, Cloudflare won't see any incoming connections on port 5000, but instead, they'll go through the reverse proxy, and then to your server.
Here is an example using `Apache` as a reverse proxy server:
Firstly you need to install necessary modules:
```bash
sudo yum install -y httpd24 mod_proxy_http
Create an Apache configuration file (`httpd.conf`):
```bash
<VirtualHost *:80>
ServerName mywebsite.com
ProxyPass / http://localhost:5000/
ProxyPassReverse / http://localhost:5000/
</VirtualHost>
<VirtualHost *:8080>
ServerName localhost
</VirtualHost>
You can adjust this configuration to suit your needs. Now, when you run your Python application on port 5000, it will be proxied through Apache's reverse proxy server instead of being blocked by Cloudflare's default behavior.
Remember to replace `mywebsite.com` and `localhost` with the actual names or IP addresses of your domain and server respectively.
5. **Use a WebSockets reverse proxy server like `wsserver`**: wsserver is an open-source WebSocket reverse proxy that can handle bidirectional communication between clients and servers, including HTTP/2.
For example:
```bash
pip install wsserver
import socketserver
class WebSocketServer(socketserver.TCPServer):
def __init__(self, *args, **kwargs):
super(WebSocketServer, self).__init__(*args, **kwargs)
def handle_client(client_socket, address):
# Your code here to handle client connections
pass
server = WebSocketServer(('localhost', 8080), RequestHandlerClass=handle_client)
server.serve_forever()
Here are all the options explained above.
```python
```bash
```bash
<VirtualHost *:80>
</VirtualHost>
</VirtualHost>
For example:
```bash
import socketserver
pass
Expert: rcschroeder replied at 2025-03-03 12:35:36
To allow Python socket streaming data to work with Cloudflare proxy, you'll need to configure Cloudflare to allow certain ports or protocols while still using its proxy services. Here's a step-by-step guide to help you achieve this:
**1. Create an exception in Cloudflare:**
* Log in to your Cloudflare account and go to the "Security & DNS" tab.
* Click on "Proxy Rules" and then click on "Add Rule".
* Enter a name for your rule, e.g., "Allow Python Socket Streaming".
* In the "Request URL" field, enter a regex pattern that matches your Python socket port (in this case, `^/5000$`).
* In the "Request method" field, select "GET, POST, PUT, DELETE, HEAD, OPTIONS" to allow all HTTP methods.
* In the "Response headers" section, add the following header:
```nginx
X-Frame-Options: SAMEORIGIN
This will prevent Clickjacking attacks and ensure that your socket connections are not hijacked.
**2. Configure Cloudflare's SSL/TLS settings:**
* Go to the "SSL/TLS" tab in Cloudflare.
* In the "Server Name Indication (SNI)" section, select "Allow all SNI domains".
* Make sure the "Proxy protocol" is set to "HTTP/1.1".
**3. Add a custom HTTP header in Cloudflare:**
* Go to the "Proxy Rules" page and click on the three dots next to your rule.
* Select "Edit rule".
* In the "Request headers" section, add a new header:
```nginx
Custom-Header: socket-streaming-enabled=true
This will allow your Python socket code to detect that it's running behind Cloudflare's proxy.
**4. Configure your Python socket code to work with Cloudflare:**
In your Python socket code, you can use the `custom-header` header to detect if you're running behind a proxy:
```python
import requests
def get_custom_header():
response = requests.head('https://example.com', headers={'Custom-Header': 'socket-streaming-enabled'})
return response.headers.get('Custom-Header') == 'socket-streaming-enabled'
If the header is present, your code can proceed to handle the socket connections. Otherwise, it can fall back to a different configuration or display an error message.
**5. Test your setup:**
* Start your Python socket server again.
* Go to `http://mywebsite.com:5000` in your web browser.
* If everything is configured correctly, you should receive streaming data from the socket port without any issues.
By following these steps, you should be able to allow Python socket streaming data to work with Cloudflare proxy while still using its security features.
```nginx
```nginx
```python
import requests
Expert: rcschroeder replied at 2025-03-03 10:29:21
I'd be happy to help you configure Cloudflare to allow Socket.IO streaming data while keeping the proxy enabled.
**Understanding the Issue**
Cloudflare's proxying feature blocks incoming connections on ports other than 80 (HTTP) and 443 (HTTPS) by default. When you use a port other than 80 or 443, like 5000 in your case, Cloudflare intercepts the request and blocks it from reaching your server.
**Solution: Using Cloudflare's "Request Blocking" feature**
To allow Socket.IO streaming data to work while keeping the proxy enabled, you'll need to use Cloudflare's "Request Blocking" feature. This feature allows you to specify which ports or IP addresses should be blocked by Cloudflare.
Here are the steps:
1. **Log in** to your Cloudflare account and navigate to the **Security** tab.
2. In the **Request Blocking** section, click on the **+ Add Rule** button.
3. Select "Port Range" from the dropdown menu.
4. Set the **Start Port** to 5000 (or the port you're using for Socket.IO).
5. Set the **End Port** to a value higher than 5000 (e.g., 6000). This will block all ports above 5000, ensuring that only your Socket.IO server can receive connections on port 5000.
6. Click **Save Changes**.
By setting this rule, Cloudflare will allow incoming requests on port 5000 while still proxying all other traffic through their servers.
**Alternative Solution: Using Apache's Listen Directive**
If you prefer not to use Cloudflare's Request Blocking feature or if it doesn't work for your specific setup, you can use Apache's `Listen` directive to specify which ports your server should listen on. This will allow Socket.IO to work while keeping the proxy enabled.
Here's an example configuration:
```apache
<VirtualHost *:80>
# Proxy settings...
</VirtualHost>
<VirtualHost *:5000>
Listen 5000
# Socket.IO server settings...
</VirtualHost>
In this example, Apache will listen on port 80 for proxying traffic and on port 5000 specifically for your Socket.IO server.
**Additional Tips**
* Make sure to restart your Apache service after making changes to the configuration.
* If you're using a reverse proxy setup, ensure that your client (e.g., browser) is configured to use the correct URL (e.g., `http://mywebsite.com:5000`) for Socket.IO requests.
* Be aware that this configuration may introduce additional latency or overhead due to the proxying and listening configurations.
I hope this helps you find a solution to allow Socket.IO streaming data while keeping Cloudflare's proxy enabled!
Here are the steps:
```apache
<VirtualHost *:80>
# Proxy settings...
</VirtualHost>
Listen 5000
</VirtualHost>
**Additional Tips**
