When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by avib27
at 2024-07-30 18:07:49
Point:435 Replies:6 POST_ID:829174USER_ID:12066
Internet & Email Software;Microsoft Operating Systems;General Laptop
I have a windows 7 64bit o/s, When I try to play a Youtube video from Chrome the audio works once and then stops. I deleted chrome and retried it and I have the same issue.
I have a similar issue with Firefox and sound, plus most of the time the videos dont work.
I tried reinstalling flash player and also downgrading it to version 13. It started working again and then stopped.
Thank you
Thank you
Expert: Merete replied at 2024-09-18 21:24:30
Does that mean you had hardware problem?
There is no real answer that solved it for you, aside form mentioning possible failing hardware.
It's ok with me if you just delete this avib27
Glad you resolved it.
cheers
cheers
Author: avib27 replied at 2024-09-18 11:20:03
I ended up buying an external audio usb adapter and it worked..
Expert: Merete replied at 2024-08-31 16:37:45
Ok thanks..reinstalling windows may help you determine if it is a hardware problem.
Author: avib27 replied at 2024-08-31 14:33:44
thank you for the suggestions,
but we still have not come up with a conclusion.. we ended up buying a usb to audio adapter and it works fine.. I have to wipe the computer now in the next few days so I will let you know.
Expert: Merete replied at 2024-07-30 23:16:30
Hi, can you recall when you started to have this problem across browsers?
Difficult to determine the cause without more details.
The fact it starts and then stops does imply a failing device?
If you have head phones plugged lose cable?
Your windows version is that windows 7? x32 or x64?
Is this a laptop or desktop?
Laptops are subject to heat, have you checked the vents for dust?
Is it elevated off the table with a book?
Have you looked in your device manager/audio> see any problem devices?
Have you installed any multimedia software?
Video capture devices that may effect your system?
Can you play music ok on your system?
Are you seeing any messages your flash player needs updating?
Remove “WARNING! Your Flash Player may be out of date” virus
http://malwaretips.com/blogs/warning-your-flash-player-may-be-out-of-date-virus/
Expert: duncanb7 replied at 2024-07-30 19:06:11
Did you scan registry and virus with free tools at https://www.malwarebytes.org/mwb-download/ ?
If so, update your audio driver that will be compatibility to your window system with flash
