When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Knowledgeable
at 2024-07-22 08:07:41
Point:500 Replies:4 POST_ID:829071USER_ID:11978
Windows 7;Microsoft Operating Systems;Microsoft Windows Operating Systems
How can I add the "Run as different user" to the default right click on icon within Windows so that this will always be an option whenever an icon or program is right clicked without the user having to hold down the Shift button while right clicking on an icon?
Expert: McKnife replied at 2024-07-25 06:16:14
With respect, knowledgeable: As I have witnessed several of your questions being solved and answers graded - do you even care to take a closer look at all the "answers"? Here for example, I provided exactly what you asked for while the other answer was about something completely different.
Expert: duncanb7 replied at 2024-07-25 06:11:49
Expert: McKnife replied at 2024-07-22 12:32:05
You are looking for a simple context menu entry for executables. Look at HKEY_CLASSES_ROOTexefileshell to get an idea. I tried and it seems I succeeded:
Windows Registry Editor Version 5.00[HKEY_CLASSES_ROOTexefileshell
unasme][HKEY_CLASSES_ROOTexefileshell
unasmecommand]@=""%1" %*""IsolatedCommand"=""%1" %*""DelegateExecute"="{ea72d00e-4960-42fa-ba92-7792a7944c1d}" 1:2:3:4:5:6:7:8:
Expert: duncanb7 replied at 2024-07-22 08:18:31
Take a look for Microsoft keyboard shortcut and switching users instrcution
http://www.sevenforums.com/tutorials/61307-switch-user-shortcut-create.html
http://www.vistax64.com/tutorials/74063-keyboard-shortcut.html
