When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by patricktam
at 2024-07-14 02:59:58
Point:500 Replies:3 POST_ID:828973USER_ID:11873
Computer Servers;Components;Miscellaneous Hardware
I am a bit new on data center infrastructure design so kindly bare with me.
Our company are provisioning a new infrastructure project and currently concerning about Rack Space allocation and most importantly power consumption estimation with details as follows:
We are purchasing a new Server Rack Cabinet with will contain 2 HP DL380 Gen8 Servers together with Two Cisco 2960x network Switches. Also, we will install LCD Console on the Rack. We need to calculate the "Total Power Required" for this configuration in (kVA) for our data center's staff power consumption allocation.
Kindly advice how to estimate the power in (kVA) for the above configuration ?
Greatly appreciate your advice in advance.
Regards
Patrick T.
Regards
Patrick T.
Author: patricktam replied at 2024-07-14 06:33:15
Thank you guys for given me such great hint. Appreciate your help.
Expert: duncanb7 replied at 2024-07-14 03:43:18
Did you read this before from HP for HP Power Calculators that also include DL380 Gen8 server ?
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?spf_p.tpst=kbDocDisplay&spf_p.prp_kbDocDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c01510445-11%257CdocLocale%253D%257CcalledBy%253D&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
Download hp power adviosr software to see it is useful or not for your case and it is just a test only
http://www8.hp.com/us/en/products/servers/solutions.html?compURI=1439951#.U8OwSflH9Zc
Expert: Kimputer replied at 2024-07-14 03:23:55
DL380G8 can operate on a single 480W PSU (usually 480W when all HDD bays are in use, a bit lower when less HDD's and PCI/X/e expansions)
Those Cisco switches operate on either 30 or 15W per port (depends on your version).
The LCD console is just a wild guess, probably around 100W.
Now add these together and you have at least a nice max value.
Example max
fully loaded DL380's = 2 x 480W = 960W
48 PoE devices at 30W = 1440W
LCD console = 100W
total = 2500W (roughly around 2.5kVA)
Example max
LCD console = 100W
