When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by brettr
at 2024-07-10 07:48:48
Point:500 Replies:3 POST_ID:828947USER_ID:10
I have several cells in one column with data. If I highlight those cells, go to the formula menu and select the average function, it will put the calculated average below the cells (assuming I started below those cells).
However, if I'm to the right of those cells and do the same, the average function tries to average cells horizontally. In this case, there might not be any cells horizontally, except the one cell in the target column. Is there a way to make functions in the Formula tab drop downs calculate highlighted cells rather than some random set?
You can see in the cells below, even though I highlighted cells A1:A4 and selected Average from the AutoSum menu drop down, it then chose to average cells A3:B3.
Expert: duncanb7 replied at 2024-07-10 08:16:56
Expert: imnorie replied at 2024-07-10 08:09:55
Can't you just goto Formulas>Insert Function, pick the function and then use the dialog to select the cells you want to use in the function.
Or type the function in the cell and when you reach the ( press the fx button next to the formula bar.
If you do that you'll get the same dialog.
Expert: duncanb7 replied at 2024-07-10 08:06:13
Step to Calculate an Average with the AutoSum Button
1-Move cursor to cell C3.
2-Choose Home tab in Excel
3-Click the down arrow next to the AutoSum button .
4-Click Average.
5-Select cells A1 to A4.
6-Press Enter., and the average of cells A1 to A4 will show in Cell C3.
See the section in the link at Calculate an Average with the AutoSum Button
http://www.baycongroup.com/excel2007/03_excel.htm
4-Click Average.
