When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by BluSkyBill
at 2024-07-10 02:04:19
Point:500 Replies:5 POST_ID:828944USER_ID:11843
Office Suites;Microsoft Office Suite;Microsoft Excel Spreadsheet Software
I have a row of numbers C31 E31, G31, I17 AND K31 WHICH MAY OR MAY CONTAIN A POSITIVE OR NEGATIVE NUMBER
I NEED TO KNOW HOW MANY CELLS CONTAIN A NUMBER. =COUNTIF(C31..K31,<>"0") WILL NOT WORK BECAUSE THERE IS TEXT IN D31, F31, H31, J31 AND L31. HOW DO I TEST FOR THE PRESENCE OF A REAL NUMBER, BE IT POSITIVE OR NEGATIVE?
Expert: duncanb7 replied at 2024-07-10 02:29:21
Please try this simple "countif" to count how many cells that is positive or negative number in range of C31:K31, and it works from my side
=COUNTIF(C31:K31,">0")+COUNTIF(C31:K31,"<0")+COUNTIF(C31:K31,"=0")
Expert: imnorie replied at 2024-07-10 02:26:08
This will count the no of cells with numbers in them in C31, E31, G31, I31 and K31.
=SUMPRODUCT(--(MOD(COLUMN(C31:K31),2)=1), --(ISNUMBER(C31:K31)))
PS I'm assuming I17 is a typo and should be I31.
Author: BluSkyBill replied at 2024-07-10 02:24:51
Excellent. Thank you
Expert: Robby Swartenbroekx replied at 2024-07-10 02:16:35
put a row below row 31 (hide it afterwards to make the layout look the same).
In Call C32 put this formula:
copy this one to the right up until cell K32
this one gives True or false.
Now count the number of true's in row 32
you can now hide row 32
Expert: johnb25 replied at 2024-07-10 02:10:04
If you are excluding 0 from your count this will work:
=COUNT(C31:K31)-COUNTIF(C31:K31,0).
If there can be no 0 then you don't need the second part.
John
John
