When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by doey
at 2024-07-08 05:23:40
Point:500 Replies:13 POST_ID:828939USER_ID:11837
Apache Web Server;Web Servers;WordPress
Hi there
I have a very simple website put in place for a client. It is a Wordpress site with only six pages. There are no secure sections and no store. It is as simple as you get.
However the client has tried to log on from a number of PCs in the office and home and it always looks for the https version of the the page. There is no secure sections of the site so therefore they will always get a security/certificate error.
I am being told that the link they are clicking is the http://xyz.com link that I sent. But I don't think that this is really the case.
So rather then me go in to their office and home to look at the local issue.... Is there a way to re-direct all https traffic to a http version of the url? Maybe through the htaccess file or some simple PHP or Wordpress way?
regards
regards
Author: doey replied at 2024-07-16 01:53:29
Sorry folks. As soon as the client received the invoice for the work to date, I have been unable to contact them. I hope to be be able to update this ASAP.
Expert: Kimputer replied at 2024-07-10 03:46:55
The code you added to your .htaccess should work, only if you enabled mod_rewrite in your apache config. Was it already enabled?
Author: doey replied at 2024-07-09 13:35:54
Hi All
I have had difficulty in trying to contact them. So I went ahead with the above code for the htaccess file and it made no difference. I entered the https url and I still got the cert error. So I put it back.
I am going to be driving by the office at some stage tomorrow and I will try and gain access to see what the loacl setup is with regards to the browsers.
Expert: Jason C. Levine replied at 2024-07-09 08:57:53
They may have "https everywhere" installed as a plugin...
That would affect everyone...not just one user.
Expert: Michael Munger replied at 2024-07-09 04:01:35
Expert: rindi replied at 2024-07-08 08:37:58
You could probably use teamviewer to check out his PC's, and repair them, without having to actually visit him.
http://teamviewer.com
Expert: Jason C. Levine replied at 2024-07-08 08:19:49
doey,
While I understand and sympathize with your situation I would also urge you to not "fix" the site in response to an issue that is clearly on the user side and only for a single user at that.
If at possible, I would either fix the user or add https to the site. I think you already know this based on the tone of your posts but taking to easy way out now could result in problems for the client later on, especially if they switch to a different developer and this "fix" isn't documented anywhere.
Author: doey replied at 2024-07-08 06:25:37
Hi There
I had to explain to them what a browser was. They then understood that they had both IE and FireFox. I was being told that they have tried from both. But I can't be sure without going to their office again, and I do not want to do that.
I am on the road at the moment. As soon as I get back to the office I will try those htaccess settings.
Expert: rindi replied at 2024-07-08 06:16:39
Have you told them to use a real browser, and not IE? Chances are it will work when using firefox...
Expert: Kimputer replied at 2024-07-08 06:04:10
Then if you have access to the .htaccess, use the solution in the first post.
Author: doey replied at 2024-07-08 06:02:34
Hi There
I'm sorry, I should have stated this earlier. I have tested it on 8 different devices (including mobile devices) and three different OSs (OSX, W7, Ubuntu). And (I'm not trying to show off here) I tested it from three different countries too.
I also sent the exact same link to two different people and they also opened it up without any issues.
So I honestly think it is something that they are doing. I have seen the setup in their office before and their PCs and network are basically held together with chewing and elastic bands. This is the reason why I want to redirect from the server as There is not enough time in the week to troubleshoot their local setup.
regards
regards
Expert: Kimputer replied at 2024-07-08 05:35:53
Since they tested it on 2 locations (office + home), it sounds they tested it pretty well. I suggest you also test it at two different locations first, as I suspect you might get the same results. If that's true, it's your web server doing this, and we have to trace down where it's doing this.
If it's not true (you don't have the same results), then they either used the wrong link (pretty unlikely where the extra "s" was snuck in during their testing), or they use some type of software or hardware appliance (router/firewall) which does it for them (out of their control). We still have to know which though, as both requires different solutions.
Expert: duncanb7 replied at 2024-07-08 05:35:15
RewriteEngine OnRewriteCond %{HTTPS} onRewriteRule (.*) http://%{HTTP_HOST}%{REQUEST_URI} [R=301,L] 1:2:3:
Put this in .htaccess file
