When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Staudte
at 2024-05-25 01:26:46
Point:500 Replies:3 POST_ID:828924USER_ID:11824
Windows Server 2012;Windows 7;Microsoft Windows Operating Systems
Hi fellow experts,
I know that drive icons and labels of SUBSTed drives can (usually) be changed by working with HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerDriveIcons. However, on my system it only works on the icon - the label always remains the same as the one of the physical drive. I have restarted the whole system - no change.
Windows Registry Editor Version 5.00[HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerDriveIconsG][HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerDriveIconsGDefaultIcon]@="C:\Windows\system32\imageres.dll,6"[HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerDriveIconsGDefaultLabel]@="HO1" 1:2:3:4:5:6:7:8:9:
What could be wrong here? (I've done that successfully for ages on a Windows 2008 Terminalserver. Now, on a brand new 2012 Terminalserver, it used to work once (just once!), briefly, but now it suddenly stopped...)
Note: It does work on other drives like the floppy or DVD - just not on the SUBSTed drive...
Thanks for your assistance,
Tom
Expert: duncanb7 replied at 2024-05-25 06:49:25
Author: Staudte replied at 2024-05-25 06:37:04
Thank you, that was it - I have recently given the physical drive a label...
From the wikipedia article: "the custom labels are only used if the host drive has no label". I have removed the label and the SUBSTed drives immediately showed their assigned labels...
Tom
Tom
Expert: duncanb7 replied at 2024-05-25 04:25:12
it is because that Substed drive label will inherit from the name of the parent drive
Take a look following sites and explain it more and recommand the fix but not a good one from removal original drive label for the lable change of Susted drive
http://techie-buzz.com/how-to/rename-virtual-subst-drives-windows.html
http://en.wikipedia.org/wiki/SUBST
Hope understand your question completely. If not, please point it out
