When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-03-10 12:26:09
Point:500 Replies:4 POST_ID:828894USER_ID:11059
Linux Networking;Network Management;Networking Hardware
I have one computer installed with linux Debain system. Since I am using it
as file access and storage only and I just use putty SSH on other my computer to remotely control the Debain computer. In other words, it is NOT neccessary the debain computer connecting keyboard, mouse or high power consumption of monitor so that
I took all device off from the debain computer.
Besides the device I take off from the debain computer, how can I further improve or reduce the power consumption from mother board of the debain computer if
it operate around 24 hours , how ?
Any linux command will do that to improve the mother board or CPU power consumption,
please advise
please advise
Author: duncanb7 replied at 2024-03-12 10:46:11
thanks for your reply
have a nice day
have a nice day
Expert: gheist replied at 2024-03-11 13:10:27
You need a wattmeter. Laptops batteries and expensive servers tend to have one builtin, rest almost never.
Author: duncanb7 replied at 2024-03-11 12:22:06
Dear gheist,
Thanks for your link and reply,
if you refer is correct, how I can compare it how much power I save on
Linux compare to Window, is there similar link for Window ?
Do you have softoware kit for download for benchmark power consumption
between Linux and Window system ?
Expert: gheist replied at 2024-03-10 17:22:32
Package called "powertop" will advise you to switch on many components
More recipes:
https://wiki.archlinux.org/index.php/Power_saving
More recipes:
