When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Thor2923
at 2024-08-02 08:29:51
Point:500 Replies:7 POST_ID:828670USER_ID:10
Network Routers;Network Switches & Hubs;Cisco PIX Firewall
I know this one is probably easy, but I just do not recall how to do it. I am trying to make a backup of all our Cisco switches and routers config file. I have already used PUTTY to connect to the ones I know and done a COPY RUNNING-CONFIG TFTP to copy the file off to my laptop. I just do not know the rest of the switch IPs so I can complete the backup procedure. I recall there is some kind of discover command???? I just want to find the switches and do not need to see the cisco phones, if this is possible. If someone could give me and example of a command I could type, I would appreciate it
Expert: craigbeck replied at 2024-08-02 14:40:50
sinfocomar - Actually if the switch doesn't have an IP or you can't talk to the management IP this will NOT help.
Also, if Telnet and HTTP is disabled, what then?
Expert: sinfocomar replied at 2024-08-02 14:24:11
craigbeck, actually an ip sniffer (see my post above) will ping and then test the telnet/http port and get back an id string. Should be enough to identify a manageable switch. Will it do?
Expert: craigbeck replied at 2024-08-02 13:54:59
All of the mentioned methods rely on either CDP or SNMP.
Unfortunately unless those protocols are running on your switches you might just have to visit each switch and connect to the console to find the details you need.
Expert: rajivkumar07 replied at 2024-08-02 10:54:28
Just logon to your switch and do -
Sh cdp neighbors
or
Sh cdp neighbors detail
Do the same thing on ur router too!
Sh cdp neighbors
or
Expert: sinfocomar replied at 2024-08-02 08:39:36
Cisco FindIT
https://supportforums.cisco.com/community/netpro/small-business/findit
SpiceWorks Network Mapping Tool
http://www.spiceworks.com/free-network-mapping-software/
Others
http://softwaresolution.informer.com/Network-Mapper/
Or you could just scan your whole subnet for devices
http://www.softpedia.com/get/Network-Tools/Protocol-Analyzers-Sniffers/IP-Sniffer.shtml
Others
Expert: max_the_king replied at 2024-08-02 08:39:32
try the command:
show cdp neighbors detail
it will work if you haven't disable cdp rin on your switches and router
hope this helps
max
try the command:
hope this helps
max
Expert: duncanb7 replied at 2024-08-02 08:34:54
What you want that is a little bit confused
Please write it clearly and kindly
You need go 192.168.1.1 on browser with "admin" at password, Right ?
