When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by philsimmons
at 2024-08-01 19:09:31
Point:500 Replies:3 POST_ID:828658USER_ID:10
Home Security;Internet Protocols;Miscellaneous Security
I have a Windows 7 computer running Norton Utilities 16. I have a couple of accounts that require the institution to recognize my computer. After entering my password and other security information I am able to access the accounts. However, the next time I go into the site (generally several days later) the institution no longer recognizes my computer and I have to go through the entire login process again. I'm guessing that it has something to do with cookies that the institution places on my computer which are cleared out during the Norton cleanup process.
Is there any way to tell Norton to ignore certain cookies and only clean out others? Or should I just disable the cookie cleaning in Norton? Or is the problem caused by something else?
Please help.
Thanks,
Phil
Please help.
Thanks,
Phil
Expert: John Hurst replied at 2024-08-02 04:09:19
@philsimmons - Thanks and I was happy to help.
... Thinkpads_User
... Thinkpads_User
Expert: John Hurst replied at 2024-08-01 19:40:02
300 points EXCELLENT
Also, if you can, under Exceptions, make an exception for Tracking Cookies. That should help. I am using Symantec Endpoint Protection and I need that exception myself for E-E. I think the exception handling for Norton is similar. Tracking Cookies is an entry in the Threat List.
... Thinkpads_User
... Thinkpads_User
Expert: duncanb7 replied at 2024-08-01 19:19:33
200 points EXCELLENT
Try to do both disable cookie clearning on Norton and
in the usual browser you use daily, for example, your FF, IE or chrome
that should solve the issue
