When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by ocaccy
at 2024-07-31 19:15:32
Point:500 Replies:6 POST_ID:828647USER_ID:11518
Miscellaneous Web Development;Miscellaneous Networking;Windows Networking
Hello there!
I have 2 Windows machines connected by TeamViewer 8 using the Internet.
In Desktop machine, I connected with lan cable. In Notebook use WI-FI EM emobile.
On 2013 July 29, not able to connect.
In the TeamViewer 8 log file appears the information below.
2013/07/29 06:56:16.994 2568 3772 S0 CConnectionThread::PingRouter(): Router Ping started2013/07/29 06:56:19.241 2568 3772 S0 CT4 CConnectionThread::CmdPingRouter(): Router Pong Received with following Hops: XXXXXXXXX YYYYYYYYY2013/07/29 07:24:52.809 2568 3652 S0 NetWatchdog: Internet is now disconnected2013/07/29 07:25:21.778 2568 3772 S0! S3 NC.WriteData.Failed42013/07/29 07:25:21.778 2568 3772 S0!! S3 NC.SendData: writeData failed with RetCode 42013/07/29 07:25:21.778 2568 3772 S0! CConnectionThread::ReconnectInternal: Trying Reconnect2013/07/29 07:25:21.778 2568 3772 S0!! CloseSocketSafely(): recv failed with error code: 10054, Errorcode=100542013/07/29 07:25:22.355 2568 3772 S0 CT4 CT.Send.CMD_RECONNECT_TO_SESSION From=XXXXXXXXX To=YYYYYYYYY L=82013/07/29 07:25:25.507 2568 3652 S0 NetWatchdog: Internet is now connected2013/07/29 18:16:31.979 2568 3524 S0 CSendCommandToMaster::SendBCommandToMaster: CC=3 CT=382013/07/29 18:16:31.979 2568 3524 S0 S3 NC.ncSocket::NotifySocketTcp(): Not waking up connection thread, because m_NoWakeUp2013/07/29 18:16:41.994 3636 3760 G1 Timeout for master message. 1:2:3:4:5:6:7:8:9:10:11:12:
What is the meaning of these messages?
What is the place to look for more information about what happened?
Management Tools, Event Viewer? Another place?
Tanks in advance, ocaccy
Author: ocaccy replied at 2024-08-09 01:37:42
Thank you, the problem has in WI-FI device.
ocaccy.
ocaccy.
Expert: duncanb7 replied at 2024-08-02 04:16:04
166 points EXCELLENT
That is not your notebook IP
Please do ipconfig/all command on the notebook
and output the result for us review
if possible aslo output for desktop with ipconfig/all
Author: ocaccy replied at 2024-08-02 04:05:10
OK,
ping 221.005.11.120>test.txt
221.005.11.120: 32 bytes of data, it has not been ping
221.005.11.120 Response from: bytes = 32 time <1ms TTL = 128
221.005.11.120 Ping statistics:
number of packets sent = 4, received = 4, lost = 0 (0% loss)
Approximate round trip time (in milliseconds):
Minimum = 0ms, Maximum = 0ms, Average = 0ms
tracert 221.005.11.120>test2.txt
Mon01 [221.005.11.120]
Number of hops through it traces the route to is up to 30:
1 <1 ms <1 ms <1 ms Mon01 [221.005.11.120]
Has complete the trace.
Expert: duncanb7 replied at 2024-08-02 00:14:16
167 points EXCELLENT
the error might cause the disconnection between desktop and notebook
that is why I ask you to do command
ping notebook's IP>junk.txt
tracert netbooks's IP>>junk.txt
and send us the junk.txt for review and check whether it is internal connection node issue
Author: ocaccy replied at 2024-08-02 00:06:24
Thank you.
Now we got the communication with the internet and Desk with Note.
I would interpret the messages in the log file above, to know what happened to break the connection on the 29th of July.
Expert: duncanb7 replied at 2024-08-01 23:13:52
Could you check whether both deskep and notebook can go exteranl web
such as www.yahoo.com to make sure external connection that is okay ?
if okay, check the connection to notebook
by ping comand
ping notebook's IP
to see any wrong
by ping comand
ping notebook's IP
to see any wrong
