When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Gerhardpet
at 2024-07-29 14:45:54
Point:500 Replies:7 POST_ID:828637USER_ID:11507
Windows 7;Windows Server 2008;Microsoft Server
I just got myself a new computer with Windows 7. I get the error below when I try to connection to multiple servers (at my customers) using RDP.
I have not problem connecting to the same servers from my desktop. Only get the error from my notebook.
Please help...
Please help...
Expert: duncanb7 replied at 2024-07-30 07:41:19
Please follows the instruction in the link to see whether you can fix the problem.
http://www.blogmynog.com/2008/10/30/because-of-an-error-in-data-encryption-this-session-will-end/
http://www.experts-exchange.com/OS/Microsoft_Operating_Systems/Server/Windows_Server_2008/Q_27324084.html
Hope you can solve it
Author: Gerhardpet replied at 2024-07-30 04:40:43
Yes all servers are password protected. Is that what you mean?
Expert: duncanb7 replied at 2024-07-30 00:23:50
do You need password to access custmer network ?
So you mean yes, Right ?
Author: Gerhardpet replied at 2024-07-29 18:51:37
@ve3ofa
Yes the desktop is also a Windows 7. The notebook is Windows 7 Pro
@duncanb7
Where are these settings?
@duncanb7
If yes, please check the option for encryption on login/passwordd again
If no, check option box to tick out the access need login/password
Expert: David Johnson, CD, MVP replied at 2024-07-29 16:21:58
Is the desktop also running Windows 7 ? Which version on the notebook? (Home Premium?)
Expert: ampxvolt replied at 2024-07-29 15:35:44
check your time zone and clock settings...sometimes encryption stuff is tied into accurate timekeeping, so if you're timezone or time are incorrect you may get security errors.
Expert: duncanb7 replied at 2024-07-29 14:51:31
