When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by 25112
at 2024-07-23 00:55:05
Point:500 Replies:9 POST_ID:828598USER_ID:11445
Web Browsers;;Windows 7
ff works.. but ie has quit bringing back any pages.. could any of the files be corrupted? if so, it is a user fault?or a virus/malware attack?
ie version is 10.0.9200.16635
there is no error message.. just a blank white screen, regardless of what website you put in.
how would you fix this?
Author: 25112 replied at 2024-07-27 03:08:15
helped- resolved. tnks
Expert: duncanb7 replied at 2024-07-26 23:00:31
Check the anti-virus software firewall setting
and check IE or window firewall setting to solve it out
Expert: duncanb7 replied at 2024-07-26 22:59:27
FF might be working for your anti-virus software settting but not IE.
I think that is easier
Expert: duncanb7 replied at 2024-07-26 22:58:23
could you disable anti-virus software for firewall setting.
your IE might be blocked by anti-virus software firewall setting
Expert: Tribus replied at 2024-07-26 13:06:14
Any updates, this should be a very easy fix, as everyone below me posted the same thing...lol
Expert: duncanb7 replied at 2024-07-23 20:01:11
125 points EXCELLENT
Did you use proxy IE ?
Just disable it on IE option-->tools-->Internet-->Connection--> LAN setting
And check auto detection setting and disable proxy
And restart computer
Expert: abhi_mahe replied at 2024-07-23 02:08:34
Please refers to the following link : -
http://browsers.about.com/od/internetexplorertutorials/ss/How-To-Reset-Ie10-To-Its-Default-Settings_4.htm
Expert: dipak1383 replied at 2024-07-23 01:46:18
Please go through below link for same.
http://answers.microsoft.com/en-us/ie/forum/ie10-windows_8/internet-explorer-10-this-page-cant-be-displayed/ae2d042d-9e2f-457b-a72f-8e0ebbbf3e8e
Expert: Tribus replied at 2024-07-23 01:35:05
Try this and see if it fixes: http://support.microsoft.com/kb/923737
