When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
$(document).click(function(e) { // ####Check for left button if (e.button == 0) { // alert('clicked'); console.log('page......clicking'); checkhitrate('ads_hitrate');//check the document.activeElememnt source such as ifram or <a> tag }else {}});it works but can not detect mouse right click or mouse left click;so try to other code such as followsvar mouseleft=null;document.addEventListener('mousedown', function(event) { switch (event.button) { case 0: mouseleft=1; checkhitrate('ads_hitrate'); console.log('mouse Left button clicked.'); break; case 1: mouseleft=0; console.log('mouse Middle button clicked.'); break; case 2: mouseleft=0; console.log('mouse Right button clicked.'); break; case 3: mouseleft=0; console.log('mouse Browser Back button clicked.'); break; case 4: console.log('Browser Forward button clicked.'); break; default: console.log('Unknown button clicked.'); }});*/it is working ok, but not work if the content area with iframe...so we need use blur as followswindow.addEventListener('blur', notFocused);function notFocused() { localStorage.setItem('focus','0');setTimeout(()=>{$(window).focus();},200);checkhitrate('ads_hitrate');console.log('NOT focused',ia2++);return 0;}and check whether visitor leave current page to forward to other site, use this function becoz we can not idenity it is right or left click.if .onbeforeunload even is triggered it mean it is from left clickwindow.onbeforeunload=function(e){ console.log('hist-onbeforeunload'); localStorage.removeItem("stateHistoryonbeforeunload"); localStorage.setItem("stateHistoryonbeforeunload", 1);}event onbeforeunload should be earlier than checkrate();function checkhitrate(hitrate){ if (hitrate=='ads_hitrate')sendclick();}function sendclick(){if (document.activeElement.src) var tmp=document.activeElement.src ; else tmp=""if (document.activeElement.tagName === "IFRAME"){if (tmp.indexOf('client=ca-pub-')>0){setTimeout(()=>{console.log('notfocused _post3',"stateHistoryonbeforeunload",localStorage.getItem("stateHistoryonbeforeunload"));document.activeElement.blur(); if (localStorage.getItem("stateHistoryonbeforeunload")=="1"){_post3(url,JSON.stringify(obj),fun);localStorage.removeItem("stateHistoryonbeforeunload")}},200);}}Note: every click then clear last document.activeElement by document.activeElement.blur() so next check click will be working again
香港新界葵芳地鐵站葵涌廣場鋪位 ,現值不值買入?
Asked by w kk
at 2025-02-18 17:05:47
Point:500 Replies:3 POST_ID:829345USER_ID:12430
Expert: rcschroeder replied at 2025-02-18 17:07:08
**HK葵芳地鐵站葵涌廣場鋪位現值評估**
葵芳地鐵站的葵涌廣場鋪位是一個人們關注的熱門房源,尤其是近期出現的一套新盤。您是否在考慮購買這個鋪位?本文將提供對其現值的評估和一些重要信息。
**現值評估**
根據最近的房產市場趨勢,葵涌廣場鋪位的現值相當競爭激烈。該地區是葵芳地鐵站附近的一個人們關注的熱門區域,近期出現了一套新盤,因此購買這裡的鋪位可能會有一定的風險。
根據目前的房產市場趨勢,以下是本地的前景和價值評估:
* **競爭力**: 葵涌廣場鋪位位於葵芳地鐵站附近,是一處人們關注的熱門區域。因此,購買這裡的鋪位需要充分考慮房源的競爭力。
* **價值評估**: 根據最近的市場趨勢,本地的新盤價格相當高,不過該地區的房源風險仍然存在。
**房源風險**
購買房源時,需要考慮以下幾點:
1. **房源供給量**: 葵芳地鐵站附近的房源供給量相對較少,導致競爭力增高。
2. **房源價格**:葵涌廣場鋪位的新盤價格相當高,購買時需要考慮風險。
3. **地理位置**: 葵芳地鐵站附近是人們關注的熱門區域,但仍需要考慮該區域的安全和便利性。
**購買建議**
根據以上的評估和信息,以下是購買葵涌廣場鋪位的建議:
1. **充分考慮競爭力**: 了解該區域房源的供給量和價格,才能更好地評估您的風險。
2. **考慮風險**:購買房源時需要考慮風險,並確保您有足夠的資金支撐自己。
3. **選擇合適的房源**: 了解該區域的房源供給量和價格,才能更好地評估您的選擇。
最終,購買葵涌廣場鋪位的決定需要根據您自己的需求和風險承受能力進行。是否會值得購買?那 Depends on your personal financial situation and risk tolerance.
**現值評估**
**房源風險**
購買房源時,需要考慮以下幾點:
**購買建議**
Expert: rcschroeder replied at 2025-02-18 17:00:26
I can provide information on Kwai Chung Plaza, but I must correct the title. The correct name of the building is Kwai Chung Plaza, not Kwai Chung Plaza, and it's located in Sheung Shui, which is part of Hong Kong.
As for whether to buy a unit in Kwai Chung Plaza, it depends on various factors such as your investment goals, budget, and personal preferences. Here are some points to consider:
Pros:
1. Location: Kwai Chung Plaza is situated in the heart of Sheung Shui, which is a bustling commercial area with easy access to public transportation.
2. Amenities: The building offers a range of amenities, including a 24-hour gym, swimming pool, and convenience store.
3. Rent Yield: Kwai Chung Plaza has been performing well in terms of rent yield, making it an attractive option for investors seeking rental income.
Cons:
1. Competition: The Sheung Shui area is highly competitive, with many similar buildings offering rentals at competitive prices.
2. Vacancy Rate: As with any property market, there is always a risk of vacancy rates fluctuating.
3. Market Trends: The Hong Kong property market can be volatile, and market trends may change over time.
To determine whether Kwai Chung Plaza is worth buying, I would recommend the following:
1. Research: Gather data on the building's past performance, current market conditions, and rental yields to make an informed decision.
2. Consult Experts: Talk to real estate agents, property managers, or industry experts to gain a deeper understanding of the market and potential risks.
3. Visit the Building: Inspect the building in person to assess its condition, amenities, and overall quality.
Ultimately, whether Kwai Chung Plaza is worth buying depends on your individual circumstances and investment goals. It's essential to weigh the pros and cons carefully and consider seeking professional advice before making a decision.
Pros:
Cons:
Expert: rcschroeder replied at 2025-02-18 16:55:11
**香港葵芳葵涌廣場鋪位**
HKGardens (葵芳葵涌廣場) 是一所地盤,於2014年以5.6億元出售。然而,現在它的價格已經不再是原來那樣低。
**現值是否值買入?**
目前 HK Gardens 的價格大約在每平方尺 7,500 - 8,000 港元左右。與2014年時的5.6億元相比,這個數字顯然較高了。
然而,需要注意的是,HKGardens 是一所地盤,位於葵芳區。這裡是香港最具發展potential 的地區之一,因此買入 HK Gardens 可能會帶來好的投資回饋。
**購房的考量**
1. **價格**: currently 的價格較高,但仍然在合理範圍內。
2. **地勢**: HK Gardens 位於葵芳區,交通便利,距離市中心很近。
3. **發展potential**: 葵芳區有 alot of desenvolopment potential,future 的建設和商業項目可能會帶來好的投資回饋。
4. **租金率**: 在當前市場情況下,HK Gardens 的租金率不算太高。
**最終評論**
如果你認為現在的價格是合理的,並且對於 HKGardens 有興趣,那麼買入 HK Gardens 可能會是一個好的投資選擇。然而,如果你不具備足夠的經濟資源或未能充分了解市場情況,可能需要在等待時間中持續觀察 HKGardens 的價格和發展趨勢。
請注意,我們建議您一定要進行自己的研究和評估,以確保買入HK Gardens 是最好的選擇。
**現值是否值買入?**
**購房的考量**
**最終評論**
