When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by test test
at 2024-09-29 00:25:49
Point:500 Replies:2 POST_ID:829284USER_ID:12424
python#javascript
it works before for both sides secoket.io connection, Suddenly today
When I connect to my socketio python server today, the javascript error is"has been blocked by CORS policy: No 'Access-Control-Allow-Origin"
and at service-side, it shown
"The client is using an unsupported version of the Socket.IO or Engine.IO protocols Error",
on python code, I have already put
Python server code:
from flask import Flask, render_template, request,Response, session, jsonify
from flask_cors import CORS
app = Flask(__name__)
CORS(app)
socketio = SocketIO(app,cors_allowed_origins='*')
Expert: Wilson Edwards replied at 2025-02-08 20:11:27
also check all package version by python3 -m pip list
if u get error:
66.90.23.28 - - [29/Sep/2024 20:00:31] "GET /socket.io/?EIO=3&transport=polling&t=PJbRigA HTTP/1.1" 400 -
reinstall package.....
python3 -m pip install python-engineio==3.13.2 &python39 -m pip install python-engineio==4.6.0
Author: test test replied at 2024-09-29 00:29:01
if it worked B4, seems system setting on python3 issue...Try to reinstall those modules related socket.io by pip3 uninstall, then reinstall, you could check your requirement.txt file for thise one you work before, and check it by pip3 list
The link may help
