When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by peter john
at 2024-08-30 22:55:47
Point:500 Replies:2 POST_ID:829259USER_ID:12425
javascript;html;editor
I want to have a reference link/example to start simple online editor
Regards
Expert: Norton Alex replied at 2024-08-30 23:04:37
And execCommand() is depreciated, now no such easy alternative or method to do this
And if u want to use other than execCommand();
u need to start to know
the function as follows;
window.getSelection(),window.getSelection().anchorNode,document.createRange (),
document.createRange ().selectNode (window.getSelection().anchorNode), etc...
Expert: Norton Alex replied at 2024-08-30 22:59:20
- <!DOCTYPE html>
- <html>
- <head>
- <meta charset='utf-8'>
- <script type="text/javascript" src="custom-text-editor.js"></script>
- <link type="text/css" rel="stylesheet" href="custom-text-editor.css"/>
- <style>
- body {font: 400 16px/1.4 'serif';}
- #container #containerHeader{
- text-align: center;
- cursor:move;
- #container #editor1 {
- border: 1px solid grey;
- height: 100px;
- width: 602px;
- margin: 0px auto 0;
- padding:10px;
- #container fieldset {
- margin: 2px auto 0px;
- width: 600px;
- height:26px;
- background-color: #f2f2f2;
- border:none;
- #container button {
- width: 5ex;
- padding: 1px 3px;
- height:30px;
- width:30px;
- background-repeat: no-repeat;
- background-size: cover;
- border:none;
- #container img{
- width:100%;
- #container .bold{
- background-image: url('data:image/png;base64,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');
- #container .italic{
- background-image: url('data:image/png;base64,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');
- #container .underline{
- background-image: url('data:image/png;base64,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');
- #container .align-left{
- background-image : url('data:image/png;base64,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');
- width:40px;
- #container .align-right{
- background-image:url('data:image/png;base64,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');
- width:40px;
- #container .align-center{
- width: 38px;
- background-size: contain;
- background-image:url('data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAOCAYAAAAvxDzwAAAABGdBTUEAALGPC/xhBQAAADRJREFUOBFjYGBg2ArE/6mEtzIBDaImADlsCAJSwhSkFgVQGoYjIMwIpdfRdAhJUYMrHQIAWPdBdW2q70gAAAAASUVORK5CYII=');
- #container .redo-apply{
- background-image: url('data:image/png;base64,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');
- #container .undo-apply{
- background-image: url('data:image/png;base64,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');
- #container .unorderedlist{
- background-image: url('data:image/png;base64,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');
- #container .orderedlist{
- background-image: url('data:image/png;base64,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');
- #container .strikethrough{
- background-image: url('data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAB4AAAAeCAQAAACROWYpAAAAAmJLR0QA/4ePzL8AAABFSURBVEjHY2AY2eAww38i4GHsmv8TCXFqxmYYPjVIzj5MUPNhXM7G5Q2ywKhm2mo+TG7ipFjzYAGjiYTs8uwwHTUPZwAAW5aYHd3noZcAAAAASUVORK5CYII=');
- #container .color-apply{
- width: 20px;
- #container #input-font{
- width: 100px;
- height: 25px;
- [contentEditable=true]:empty:not(:focus):before{
- content:attr(data-text);
- color:#888;
- #container .loader {
- border: 6px solid #f3f3f3;
- border-top: 6px solid #3498db;
- border-radius: 50%;
- width: 20px;
- height: 20px;
- animation: spin 2s linear infinite;
- margin: 0 auto;
- line-height: 20px;
- /* @keyframes spin {
- 0% { transform: rotate(0deg); }
- 100% { transform: rotate(360deg); }
- </style>
- <script>
- //https://stackoverflow.com/questions/43778468/create-simple-text-editor-javascript
- function chooseColor(){
- var mycolor = document.getElementById("myColor").value;
- document.execCommand('foreColor', false, mycolor);
- function changeFont(){
- var myFont = document.getElementById("input-font").value;
- document.execCommand('fontName', false, myFont);
- function changeSize(){
- var mysize = document.getElementById("fontSize").value;
- document.execCommand('fontSize', false, mysize);
- function checkDiv(){
- var editorText = document.getElementById("editor1").innerHTML;
- if(editorText === ''){
- document.getElementById("editor1").style.border = '5px solid red';
- function removeBorder(){
- document.getElementById("editor1").style.border = '1px solid transparent';
- </script>
- </head>
- <body>
- <div id="container" >
- <fieldset>
- <button class="fontStyle italic" onclick="document.execCommand('italic',false,null);" title="Italicize Highlighted Text"></button>
- <button class="fontStyle bold" onclick="document.execCommand( 'bold',false,null);" title="Bold Highlighted Text"></button>
- <button class="fontStyle underline" onclick="document.execCommand( 'underline',false,null);"></button>
- <select id="input-font" class="input" onchange="changeFont (this);">
- <option value="Arial">Arial</option>
- <option value="Helvetica">Helvetica</option>
- <option value="Times New Roman">Times New Roman</option>
- <option value="Sans serif">Sans serif</option>
- <option value="Courier New">Courier New</option>
- <option value="Verdana">Verdana</option>
- <option value="Georgia">Georgia</option>
- <option value="Palatino">Palatino</option>
- <option value="Garamond">Garamond</option>
- <option value="Comic Sans MS">Comic Sans MS</option>
- <option value="Arial Black">Arial Black</option>
- <option value="Tahoma">Tahoma</option>
- </select>
- <button class="fontStyle strikethrough" onclick="document.execCommand( 'strikethrough',false,null);"><strikethrough></strikethrough></button>
- <button class="fontStyle align-left" onclick="document.execCommand( 'justifyLeft',false,null);"><justifyLeft></justifyLeft></button>
- <button class="fontStyle align-center" onclick="document.execCommand( 'justifyCenter',false,null);"><justifyCenter></justifyCenter></button>
- <button class="fontStyle align-right" onclick="document.execCommand( 'justifyRight',false,null);"><justifyRight></justifyRight></button>
- <button class="fontStyle redo-apply" onclick="document.execCommand( 'redo',false,null);"><redo></redo></button>
- <button class="fontStyle undo-apply" onclick="document.execCommand( 'undo',false,null);"><undo></undo></button>
- <button class="fontStyle orderedlist" onclick="document.execCommand('insertOrderedList', false, null);"><insertOrderedList></insertOrderedList></button>
- <button class="fontStyle unorderedlist" onclick="document.execCommand('insertUnorderedList',false, null)"><insertUnorderedList></insertUnorderedList></button>
- <input class="color-apply" type="color" onchange="chooseColor()" id="myColor">
- <!-- font size start -->
- <select id="fontSize" onclick="changeSize()">
- <option value="1">1</option>
- <option value="2">2</option>
- <option value="3">3</option>
- <option value="4">4</option>
- <option value="5">5</option>
- <option value="6">6</option>
- <option value="7">7</option>
- <option value="8">8</option>
- </select>
- <!-- font size end -->
- </fieldset>
- <div id="editor1" contenteditable="true" data-text="Enter comment...."></div>
- </div>
- </body>
- </html>
I put it at https://computer28.com/learn-center/editor.html
