When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rwniceing
at 2024-09-11 15:00:45
Point:500 Replies:7 POST_ID:829234USER_ID:12079
Linux;;Apache Web Server
My VPS server is hosted to one VPS hosting company.
Whatever I try to enable selinux on my apache linux CentOS with many linux command operation, it is still not enabled, Why ?After posting related question here, and the answer is not found yet.
And I talked to my hosting company, he replied:
My question is
VPS hosting company has ability to restrict user to enable selinux even I have installed selinux and done all selinux instruction on my VPS server since it is Virtualization server , they are able to restrict all VPS users to enable selinux, right ? If so, I will give up to enable selinux on my VPS server
Rwniceing
We use OpenVZ virtualization (most popular VPS virtualization system), which doesn't support selinux for security reasons, i am sorry, but we have no option to enable it.
My question is
Rwniceing
Author: rwniceing replied at 2024-09-11 15:34:16
mugojava, thanks for your reply after this thread is closed. All agree it now .
Expert: mugojava replied at 2024-09-11 15:33:05
That is correct. OpenVZ does not support SELinux. If you require SELinux, you will have to go with another virtualization method.
Expert: exploitedj replied at 2024-09-11 15:26:14
And to answer, yes, I agree. They are probably bound by this limitation.
Author: rwniceing replied at 2024-09-11 15:25:37
Thanks for your reply
Expert: exploitedj replied at 2024-09-11 15:23:58
Ha ha, small world. You are the "other guy" I was going to check on.
Author: rwniceing replied at 2024-09-11 15:22:22
In other words, you agree it my last question in my last post, right ?
If so, I will close this thread
Expert: exploitedj replied at 2024-09-11 15:20:02
Shoot. I just found this, http://wiki.centos.org/HowTos/Virtualization/OpenVZ
"Unfortunately SELINUX is not compatible with nor included in the OpenVZ kernel. To disable SELINUX, edit the /etc/sysconfig/selinux config file with your preferred text editor and set it to disabled:
SELINUX=disabled "
I have to save some other guy some time, with a similar post. BRB.
SELINUX=disabled "
