When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Starquest321
at 2024-09-06 05:31:05
Point:500 Replies:29 POST_ID:829222USER_ID:12095
Apache Web Server;Linux;Linux Distributions
I am having issues with folder permissions:
On applications I keep getting the following errors:
Cannot create folder: /var/www/html/fileserver/temp__vp49720pjqi67i0jsci2lljb56/x_message1
When installing roundcube - save errors.. the read :: write permissions are not working.
I have given the whole HTML (and recursive subfolders) 777 permissions. Is there some other settings?
Expert: Dejan Vasiljevic replied at 2024-09-10 17:05:56
This is the last message that was probably the solution of this problem and I will post it so the further question have an answer for this, and in future people who search for the same problem could have an example of answer -
"Can You go to Your /tmp folder and create .htaccess file and in there copy this -
# Set the catch-all handler to prevent scripts from being executed.
SetHandler Drupal_Security_Do_Not_Remove_See_SA_2006_006
<Files *>
# Override the handler again if we're run later in the evaluation list.
SetHandler Drupal_Security_Do_Not_Remove_See_SA_2013_003
</Files>
# If we know how to do it safely, disable the PHP engine entirely.
<IfModule mod_php5.c>
php_flag engine off
</IfModule>
# PHP 4, Apache 1.
<IfModule mod_php4.c>
php_flag engine off
</IfModule>
# PHP 4, Apache 2.
<IfModule sapi_apache2.c>
php_flag engine off
</IfModule>
or for newer version
# Turn off all options we don't need.
Options None
Options +FollowSymLinks
<Files *>
</Files>
php_flag engine off
</IfModule>
Thanks,
D.
<Files *>
</Files>
php_flag engine off
</IfModule>
# PHP 4, Apache 1.
php_flag engine off
</IfModule>
# PHP 4, Apache 2.
php_flag engine off
</IfModule>
Options None
<Files *>
</Files>
php_flag engine off
</IfModule>
Thanks,
D.
Author: Starquest321 replied at 2024-09-08 17:24:33
Not updated anything. . . and if you tell me which commands to check I will.
Expert: Dejan Vasiljevic replied at 2024-09-08 17:19:22
84 points EXCELLENT
Did You or did You not updated anything recently ?
Author: Starquest321 replied at 2024-09-08 17:10:52
Trying anything . . .creating the temp did not do the trick
Expert: Dejan Vasiljevic replied at 2024-09-08 17:09:16
Starquest321,
Why did You created new user?
Thanks,
D.
Thanks,
D.
Author: Starquest321 replied at 2024-09-08 16:44:18
I have created a "new" user .. called "TEMP" to try to solve this issue. Should I put in the group apache to see if this resolves the issue?
The user has "ROOT" rights
Author: Starquest321 replied at 2024-09-08 14:36:12
Dejan: Can you give me specific steps to take?
Author: Starquest321 replied at 2024-09-08 14:33:26
ps faux | grep httpd
root 1080 0.0 1.9 516204 20132 ? Ss Sep07 0:05 /usr/sbin/httpd -DFOREGROUND
apache 4436 0.0 0.7 342356 7600 ? S 05:32 0:00 \_ /usr/sbin/httpd -DFOREGROUND
apache 4438 0.0 1.0 518424 10480 ? S 05:32 0:00 \_ /usr/sbin/httpd -DFOREGROUND
apache 4439 0.0 1.0 518424 10480 ? S 05:32 0:00 \_ /usr/sbin/httpd -DFOREGROUND
apache 4441 0.0 1.0 518424 10480 ? S 05:32 0:00 \_ /usr/sbin/httpd -DFOREGROUND
apache 4442 0.0 3.8 543360 38440 ? S 05:32 0:00 \_ /usr/sbin/httpd -DFOREGROUND
apache 4551 0.0 1.0 518424 10480 ? S 05:49 0:00 \_ /usr/sbin/httpd -DFOREGROUND
apache 4554 0.0 3.7 543032 38108 ? S 05:49 0:00 \_ /usr/sbin/httpd -DFOREGROUND
apache 4555 0.0 1.0 518424 10480 ? S 05:49 0:00 \_ /usr/sbin/httpd -DFOREGROUND
apache 4556 0.0 1.0 518424 10480 ? S 05:49 0:00 \_ /usr/sbin/httpd -DFOREGROUND
apache 4557 0.0 1.0 518424 10480 ? S 05:49 0:00 \_ /usr/sbin/httpd -DFOREGROUND
apache 4563 0.0 0.9 518288 9512 ? S 05:50 0:00 \_ /usr/sbin/httpd -DFOREGROUND
root 4680 0.0 0.0 112640 980 pts/1 S+ 06:37 0:00 | \_ grep --color=auto httpd
Expert: Dejan Vasiljevic replied at 2024-09-08 14:23:15
Starquest,
That is why I said that You need to create it, because it should be owned by user, not by Apache, and that is why You are getting an error. Create a folder and it will temptemp for temp folder and it will give it ownership to apache.
Thanks,
D.
Thanks,
D.
Expert: Seth Simmons replied at 2024-09-08 14:09:18
Could it be possible that the apache is NOT the user that is running the website?
what is the user account listed?
Author: Starquest321 replied at 2024-09-08 13:59:26
I don't have a "temp" folder. I think it created on the fly.
Expert: Dejan Vasiljevic replied at 2024-09-08 13:26:48
83 points EXCELLENT
Hi Starquest321,
I saw the almost same problem as this one. The problem might not be in permissions/rights, but the owner. Try to change temp folder to anything else, like temptemp and it will create it with apache rights, and this should solve Your problem about it.
Thanks,
D.
Thanks,
D.
Author: Starquest321 replied at 2024-09-08 13:16:32
RIght now I have set for all files in the directory:
-rwxrwx---. 1 apache apache 62620 Sep 6 03:53 text.php
So user, group apache can read, write, execute ... but I still cannot create folder. COuld it be the application is not logging on properly?
Author: Starquest321 replied at 2024-09-08 07:30:28
The fileserver directory is inside the "application" ...
I get also general errors when trying to create directories:
Cannot create folder: /var/www/html/application/temp__jceqclgkmptva4qnug8bv34vh7/x_voicemail
The error that I get is from file:
http://192.168.197.130/application/useradd.php
How do I know which user is trying to run the script?
Expert: Seth Simmons replied at 2024-09-08 07:19:44
I have made sure that there is a directory called Fireserver.
i do not see a fileserver folder in that directory listing; only 5 files
I noticed that only the group has write permission - but not the user.
not an issue since the user account is rwx; only need to change if a different user in the same group needed write access
Author: Starquest321 replied at 2024-09-08 06:42:03
I have ran the following command on the box now:
ls -al /var/www/html/
drwxr-x---. 4 apache apache 95 Sep 5 22:55 .
drwxr-xr-x. 4 apache apache 31 Sep 5 15:35 ..
-rwxr-x---. 1 apache apache 12 Aug 30 19:33 info.php
-rwxr-x---. 1 apache apache 12288 Aug 30 19:35 .info.php.swn
-rwxr-x---. 1 apache apache 12288 Aug 30 19:32 .info.php.swp
drwxrwx---. 24 apache apache 36864 Sep 5 20:22 application
drwxr-x---. 11 apache apache 4096 Jan 8 2012 webmail
The directory: application also is owned by user :: group apache
How can I change that?
Author: Starquest321 replied at 2024-09-08 06:26:09
What is the command to achieve the following:
Can you please give me the specific commands to do the following:
1. Change the "application" directory to the group apache (with all files and subfolders)
2. Give apache write permissions
I have an option to do with this with filizilla. . .but its not saving. Maybe that is where I am going wrong.
Need urgent help
Need urgent help
Expert: samri replied at 2024-09-07 22:01:58
83 points EXCELLENT
HI,
I am just picking this up from the last few msgs;
However, from your ls -al listing above, the folder/path "/var/www/html/fileserver/" does not exist. Maybe you need to check your coding on how the file is written.
Quickest thing that I can think of for now would be to creat the folder;
or,
And make sure the owner is apache, group is apache.
or,
Author: Starquest321 replied at 2024-09-06 18:34:05
This is the current status now:
Seems like both are apache for user and group. But still no luck:
[root@s ~]# ls -al /var/www/html/
total 88
drwxrwxr-x. 4 apache apache 95 Sep 5 22:55 .
-rwxrwxr-x. 1 apache apache 12 Aug 30 19:33 info.php
-rwxrwxr-x. 1 apache apache 12288 Aug 30 19:35 .info.php.swn
-rwxrwxr-x. 1 apache apache 12288 Aug 30 19:32 .info.php.swp
drwxrwxr-x. 24 apache apache 36864 Sep 5 20:22 application
drwxrwxr-x. 11 apache apache 4096 Jan 8 2012 webmail
total 88
Expert: Seth Simmons replied at 2024-09-06 17:46:44
you changed ownership group? what about user?
directory permissions are 755 so either you change the user also to apache account or change that folder permission to 775 since group rights are r-w thus can't write there
Author: Starquest321 replied at 2024-09-06 15:37:58
Just read a post that the user trying to access the "html" is actually apache. . . but my ownership is root. So I changed owership :: group to apache. Still no luck.
Author: Starquest321 replied at 2024-09-06 15:25:20
The installation was done using command line while logged in as 'Root'
Author: Starquest321 replied at 2024-09-06 15:24:22
I changed back to 755 permissions since I thought that giving www a 777 would be completely careless and insecure. I don't know how this should be done - so I am stuck.
When my application tries to create a directory it's running into the error:
Cannot create folder: /var/www/html/application/temp__474k3qu2rvfkodoin11rvjjgp3/x_message1
What should be the permissions? How do I know which user is trying to run this? Is this a user different than the mysql user?
Expert: Seth Simmons replied at 2024-09-06 15:18:19
83 points EXCELLENT
based on your output that doesn't appear to be the case; directory permissions are 755
how is this being installed? if this is being done through a web site installation (as opposed to command line) then whatever user account is running the apache process should have permissions to that folder structure; right now it's only root
if it's the application folder, then change the permissions appropriately
Author: Starquest321 replied at 2024-09-06 14:36:41
Could it be possible that the permissions on that /var/www/html should be set www-data:root?
I am reading it in various forms, but I don't have a user like that. . .
When I try the command:
[root@s360 ~]# chown -R www-data:root /var/www/html/
chown: invalid user: ‘www-data:root’
Author: Starquest321 replied at 2024-09-06 14:19:14
Note that fileserver is a directory within "application"
[root@s360 ~]# ls -al /var/www/html/
total 88
drwxr-xr-x. 4 root root 95 Sep 5 22:55 .
drwxr-xr-x. 4 root root 31 Sep 5 15:35 ..
-rwxr-xr-x. 1 root root 12 Aug 30 19:33 info.php
-rwxr-xr-x. 1 root root 12288 Aug 30 19:35 .info.php.swn
-rwxr-xr-x. 1 root root 12288 Aug 30 19:32 .info.php.swp
drwxrwxr-x. 24 root root 36864 Sep 5 20:22 application
drwxr-xr-x. 11 501 80 4096 Jan 8 2012 webmail
[root@s360 ~]# ls -al /var/www/html/application/fileserver
total 56
drwxrwxr-x. 2 root root 6 Sep 5 20:21 .
drwxrwxr-x. 24 root root 36864 Sep 5 20:22 ..
[root@s360 ~]#
total 88
total 56
[root@s360 ~]#
Expert: Milind Koyande replied at 2024-09-06 12:33:18
83 points EXCELLENT
Is it possible to share the output of
Author: Starquest321 replied at 2024-09-06 08:27:32
I installed with root access. No issue with disk space.
Expert: rwniceing replied at 2024-09-06 08:02:25
84 points EXCELLENT
you install it with root access ?
Did you check the disk space by "df -h" ?
