When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Jagwarman
at 2024-09-05 06:39:49
Point:500 Replies:5 POST_ID:829219USER_ID:12093
I am using this formula that works fine until it can't find wjat it is looking for
=IF(R34="Match","",VLOOKUP(LEFT(D34,4),MatchData!L:S,8,))
but if it can't find it returns #N/A
I have tried to add ISERROR but can't get it to work.
Please help instead of #N/A I want it to say Not Found
Author: Jagwarman replied at 2024-09-05 07:06:14
many thanks
Expert: DanCh99 replied at 2024-09-05 07:06:13
by the way, it's much easier for us to work on an example sheet (with no confidential data on it, of course) if you can attach them...
Expert: DanCh99 replied at 2024-09-05 07:04:40
=IF(R34="Match","",VLOOKUP(VALUE(LEFT(D34,4)),MatchData!L:S,8,FALSE))
I think you need the VALUE command to properly extract a numeric to satisfy the VLOOKUP.
Expert: rwniceing replied at 2024-09-05 07:04:30
=IF(R34="Match","",IF(ISERROR(VLOOKUP(LEFT(D34,4),MatchData!L:S1,8,TRUE)),"NOT FOUND",VLOOKUP(LEFT(D34,4),MatchData!L:S1,8,TRUE)))
You can try this, you need to specifiy exact match with TRUE
Expert: Neilsr replied at 2024-09-05 06:44:01
=IFERROR(IF(R34="Match","",VLOOKUP(LEFT(D34,4),MatchData!L:S,8,)),"Not Found")
