When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Qutub Parawala
at 2024-08-31 07:58:40
Point:500 Replies:8 POST_ID:829213USER_ID:12087
Microsoft Operating Systems;Web Applications;Web Services
hi,
i am not able to browse my website link in IIS when i try to browse the link through inetmgr its showing “Page cannot be displayed . . . cannot find server or dns errorâ€i reset the iis and when i check the httperr log (C:WINDOWSsystem32LogfilesHTTPERR) it showing “Connection_refused†in the log file please can you give me advise how can i resolve this issue.
Author: Qutub Parawala replied at 2024-09-06 00:11:26
Thanks for advise its work after change the registry value.
Expert: joinaunion replied at 2024-08-31 11:34:47
Give this a read. This points to a memory depletion.
http://blogs.msdn.com/b/chaun/archive/2008/02/21/page-cannot-be-displayed-due-to-non-paged-pooled-memory-depletion.aspx
Expert: rwniceing replied at 2024-08-31 09:32:03
The article explained the root cause, please read "cause" section at that link. And you can try its resolution since it can set it back (adsutil.vbs set /w3svc/1/SecureBindings ":443:") if not working
Author: Qutub Parawala replied at 2024-08-31 08:59:27
is it nonpaged issue ?
Author: Qutub Parawala replied at 2024-08-31 08:55:56
on above link one command i have to run on my server is it create any problem to my server ? does its change any settings or what please advise before i run this command.
Expert: rwniceing replied at 2024-08-31 08:36:39
this link describe how to solve the "page can not be displayed" when through HTPPS from the Microsoft admin at http://support.microsoft.com/kb/290391
Did you read this before ?
Author: Qutub Parawala replied at 2024-08-31 08:33:49
yes normal http is ok
Expert: rwniceing replied at 2024-08-31 08:22:26
normal http site is okay ? just https SSL site has issue ?
