When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rwniceing
at 2024-08-31 05:20:38
Point:500 Replies:9 POST_ID:829210USER_ID:12079
Shell Scripting;Linux;C++ Programming Language
Linux script is more or less like interpreted scrip as javascript but working for different platform such as one is for browsers and other is for linux system script, Right ? Is linux-script based on Assembly , C or C++ language ?
I tried one benchmark code speed testing for "fop loop" with linux "time" command ,
The execution time of the C++ program is around 0.01 seconds(11 ms) but for the linux script,
the time is 34 seconds that is totally greater than C++.
Do you have idea to explain the different result ? Or the time difference is depended on
some linux system differnt setting on using memory for script and binary program ?
And attached just simple example code for "for loop" program with iteration of 2e6
Rwniceing
Bash shell for loop with 2e6;
Rwniceing
#!/bin/bashfor ((i=1;i<=200000000;i++))doa="$[1234+$5678+$i]"b="$[1234*5678+$i]"c="$[1234/2+$i]"done 1:2:3:4:5:6:7:
C++ for loop with 2e6
int main(){int max = 2e6;"int a,b,c;" // CODE YOU WANT TO TIME int start = getMilliCount();" for (int i = 0;" i <" max;" i++) { a = 1234 + 5678 + i;" b = 1234 * 5678 + i;" c=1234/2+i;" }return 0;"} 1:2:3:4:5:6:7:8:9:10:11:12:
Expert: mbertl replied at 2024-08-31 06:41:38
Your are very welcome! Thanks for accepting the answer.
regards,
fred
regards,
fred
Author: rwniceing replied at 2024-08-31 06:36:28
the script's advantage and disadvantage mentioned in this link and some wording for
comparision from conventional program langugage at http://en.wikipedia.org/wiki/Shell_script
Thanks for your reply
Expert: mbertl replied at 2024-08-31 06:28:46
No, i'm very sorry, i have no article about that. There might be tons of articles, when you search for performance tuning when coding scripts or applications. So i'm afraid, i have to point you to the search engines available.
Author: rwniceing replied at 2024-08-31 05:58:12
Optional question: Do you have any article to talk about this topic ?
Expert: mbertl replied at 2024-08-31 05:50:22
Absolutely correct.
Author: rwniceing replied at 2024-08-31 05:49:16
And it might be in shell linux script, it will create a lot of child process and memory to to complete task which is not as efficient as C++ binary code process. But for c++ binary code after complied and linked, it just create single thread or process and the memory is used less than script .
Expert: mbertl replied at 2024-08-31 05:45:55
The Script in Linux runs within your shell (mostly bash, i guess). The Shell interprets the commands, hast to translate them and executes them.
Author: rwniceing replied at 2024-08-31 05:36:08
So for ((i=1;i<=200000000;i++)) is just command more than language in linux-script, Right ? How linux interprete the "for loop", (probably it won't translate to assembly langauge since it wont be compiled or linked) and I think linux system treat the "for loop" as command and directly call its related binary code to achieve the result, Right ? If so, the speed might not be too slow on linux-script.
for example,
$ x="a"
$ echo x
a
for example,
$ x="a"
$ echo x
a
Expert: mbertl replied at 2024-08-31 05:29:15
Linux script is an interpreter language, while C++ Code ist compiled into machine code. Therefor C++ programs are that faster to run, because they run w/o that layer of the interpreter.
