When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rwniceing
at 2024-08-31 00:35:26
Point:500 Replies:9 POST_ID:829209USER_ID:12079
Linux;;Apache Web Server
1- Could I use 2e8 for 200000000 for linux script ?
2- and I try the similar for loop in php, c,c++ and asp that is okay
no any memory allocation error.
But when run it on linux shell on my VPS server apache centos6, it came out error, Why ?
#./for
./for: xmalloc: cannot allocate 9 bytes (1873698816 bytes allocated)
How to solve this out
for file
#./for
for file
#!/bin/bashfor i in {1..200000000}do a=1234+5678+ib=1234*5678+ic=1234/2+i#echo $idone 1:2:3:4:5:6:7:8:
Expert: ozo replied at 2024-08-31 19:21:07
I think
for ((i=1;i<=$[bc 2*10^6];i++))
would have to be
for ((i=1;i<=$(echo "2*10^6"|bc);i++))
But that would cause an echo process and a bc process to be forked 2*10^6 times, so you probably wouldn't want to do it that way.
would have to be
Author: rwniceing replied at 2024-08-31 02:39:15
Now it works for question-1 with bc command and question-2
#!/bin/bashfor ((i=1;i<=$[bc 2*10^6];i++))doa="$[1234+$5678+$i]"b="$[1234*5678+$i]"c="$[1234/2+$i]"#echo Welcome $idoneecho $a=$b=$c 1:2:3:4:5:6:7:8:9:
Thanks for your reply and the code need to be checked for other value
Expert: gheist replied at 2024-08-31 02:27:35
200 points EXCELLENT
You cannot use 2e8
It is more like ${bc 2*10^8)
Author: rwniceing replied at 2024-08-31 02:21:17
question-2 is solved by ozo after change for loop,for (( i=1; i<=200000000; ++i )); and the memory
allocation error is gone.
and it is interesting the memory usage for that for syntax is different from "for i in (1 ..200000000)" that won't use back the memory from previous i, instead, it will create many copy until memory reach to the limit before i= 200000000.
And it seems solving question-1 needs more time
Expert: gheist replied at 2024-08-31 01:57:37
sysctl vm.overcommit_memory=1 >> /etc/sysctl.conf
will allow to allocate memory lazy way so it is not really allocated unless accessed.
Author: rwniceing replied at 2024-08-31 01:56:23
This two sites may assist the question-1 for nature log with bc command for 2e8
http://advantage-bash.blogspot.hk/2012/03/logarithm-and-anti-logarithm.htmlhttp://www.linuxfromscratch.org/blfs/view/7.4/general/bc.html
Expert: ozo replied at 2024-08-31 01:11:19
300 points EXCELLENT
I'm not sure if you'd call this a short hand
e=`yes | head | tr -c 0 0`
for (( i=1; i<=2${e::8}; ++i )); do echo $i ; done
or
e=2$(for e in {1..8}; do echo -n 0 ; done)
for (( i=1; i<=$e; ++i )); do echo $i ; done
or
for (( i=1; i<=2$(yes 0 | head -8|tr -cd 0); ++i )); do echo $i ; done
or
or
Author: rwniceing replied at 2024-08-31 00:51:05
no short hand writing for 200000000 ?
Expert: ozo replied at 2024-08-31 00:49:22
{1..200000000} will attempt to expand the entire list of 200000000 white space separated numbers
it would be much more memory efficient to use something like
