When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rwniceing
at 2024-08-26 03:57:24
Point:500 Replies:3 POST_ID:829202USER_ID:12079
Active Server Pages (ASP);;JavaScript
Dear Exerts,
I try to extract the total execution time of the for loop in the following asp code
and since vbscript is not doing well with miilli-second extraction, so I use javascript code
for extracting time in ms from start and ending of for loop.
Now the code is working, it show the Start and End time. But how to
do substraction on start-time - end time ?
I tried put the end-time javascript right after <% %> similar code to the start time javascript code. But it showed the wrong result that is why I put into head tag for end time javascript code.
Any better approach for doing that ?
Rwniceing
Rwniceing
<!DOCTYPE html><html><script language=javascript runat=server>var myvar = Date.UTC(a.getFullYear(),a.getMonth(),a.getDay(),a.getHours(),a.getMinutes(),a.getSeconds(),a.getMilliseconds()); response.write("Start time in ms: " + myvar ); </script><%Dim i,a,b,cfor i = 1 to 2e6a=1234+5678+ib=1234*5678+ic=1234/2+inextresponse.write("<br/>(i,a,b,c)=" & i & "=" & a & "=" & b & "=" &c & "<br/>")%><body></body><head runat="server"> <title>Demo Page for Test</title> <script language="javascript" type="text/javascript" > var a = new Date();var myvar = Date.UTC(a.getFullYear(),a.getMonth(),a.getDay(),a.getHours(),a.getMinutes(),a.getSeconds(),a.getMilliseconds()); document.write("End time in ms: ",myvar); </script></head></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:
Author: rwniceing replied at 2024-08-29 05:34:59
Done and thanks for your reply
Author: rwniceing replied at 2024-08-29 05:33:16
<%Option ExplicitResponse.Buffer = False ' not needed but lets you see the output as it is produced instead of all at once%> 1:2:3:4:5:6:7:
That is why on my topic post code, it will response.write the output after the for loop completion
and the start and end time is also correct but just echo out at the same time that is strange I feel.
Probably it is caused by the setting on response.buffer.
Expert: Robert Schutt replied at 2024-08-29 05:26:55
I've struggled with this in the past (regarding time zone offset which also seemed strangely unavailable in ASP/VB). One of the problems when mixing languages and embedded code blocks with server script tags is keeping tabs on which code is executed when. One way to avoid this problem is to wrap the needed (server side) javascript in a function which can be called from (server side) vb script. Your specific situation could be solved as follows:
<%Option ExplicitResponse.Buffer = False ' not needed but lets you see the output as it is produced instead of all at once%><!DOCTYPE html><html><body> <script language="jscript" runat="server"> function getTime() { var a = new Date(); return Date.UTC(a.getFullYear(),a.getMonth(),a.getDay(),a.getHours(),a.getMinutes(),a.getSeconds(),a.getMilliseconds()); } </script><%Dim startTime, endTimestartTime = getTime()Response.Write "Start time in ms: " & startTimeDim i,a,b,cfor i = 1 to 2e6a=1234+5678+ib=1234*5678+ic=1234/2+inextresponse.write("<br/>(i,a,b,c)=" & i & "=" & a & "=" & b & "=" &c & "<br/>")endTime = getTime()Response.Write "End time in ms: " & endTimeResponse.Write "<br>Elapsed time in ms: " & (endTime - startTime)%></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:
Note that I added some bells and whistles just for fun...
