When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rwniceing
at 2024-08-28 00:37:41
Point:500 Replies:9 POST_ID:829198USER_ID:12079
C Programming Language;;C++ Programming Language
My question is on the following testing C code in test.c
Question-1
keyword of __cpluscplus is stand for the file extension of the running file such as test.c, Right ?
so test.c file has c file extension so the following typedef will be active, right ?
#ifndef __cplusplus
typedef unsigned char bool;
static const bool False = 1;
static const bool True = 0;
#endif
Question-2 What is different between defined the function as macro and define function in the code body ?Any advantage over others ? Both I tested to get the same result.
#define getmax_macro(a,b) ((a)>(b)?(a):(b))
int getmax(int a, int b){}
Rwniceing
test.c
Question-1
#ifndef __cplusplus
#endif
Rwniceing
test.c
#include <stdio.h>#ifndef __cplusplustypedef unsigned char bool;static const bool False = 1;static const bool True = 0;#endif#define getmax_macro(a,b) ((a)>(b)?(a):(b))int getmax(int a, int b){ if (a>b)return a;else return b;}int main(){ #if !defined(__BOOL_DEFINED) printf("bool is not supported"); #elif defined(__BOOL_DEFINED) printf("bool is supported%d",__BOOL_DEFINED); #endif bool arr[2] = {false, true}; printf("bool is supported%d",arr[0]); int x=5, y; y= getmax_macro(x,2); printf("getmax_macro: %d",y); y= getmax(x,2); printf("getmax: %d",y); return 0;} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:
Author: rwniceing replied at 2024-08-30 21:44:54
Thanks for your reply
Author: rwniceing replied at 2024-08-28 05:13:55
I mean reliable that is more safe enough to get the final result from function than macro .
Macro is not able to be debugged , Right as zoppo mentioned it ?
Expert: ozo replied at 2024-08-28 05:03:22
I'm not sure what you mean by reliable.
You can rely on no more than that both should behave as specified by the language standard.
There are things that can be done with macros and not with functions, and there are things that can be done with functions and not with macros.
There can be situations where a macro will run faster, and there can be situations where a function will run faster.
Author: rwniceing replied at 2024-08-28 04:54:20
ozo, in other words, function is more reliable than macro, right ? macro is good for small or simple code that run
faster than a function.
Which method(macro/function) will run faster and use less memory?
Author: rwniceing replied at 2024-08-28 04:50:43
Thanks for your reply and also I found one process flow for compiler process on C/CPP
at this link, https://www3.ntu.edu.sg/home/ehchua/programming/cpp/gcc_make.html#zz-1.4
and described the header file and enable macro file with .i and .ii file extension
Expert: ozo replied at 2024-08-28 04:49:06
100 points EXCELLENT
getmax(++a,++b) would work behave differently when called as a macro rather than a function
Expert: Zoppo replied at 2024-08-28 02:54:00
200 points EXCELLENT
Yes, macros are expanded in a pre-compile step by the preprocessor (http://en.wikipedia.org/wiki/Preprocessor)
When to put functionality into a function or to a macro depends on the need (and a bit on the habit of the programmer).
Macros IMO have some disadvatages compared to functions, i.e.:
- they (at least with IDEs/debuggers I know) cannot be debugged
- it's not possible to overload functions (see http://www.learncpp.com/cpp-tutorial/76-function-overloading/)
- parameters have no type, so i.e. it's not possible to write a SWAP macro
- with functions the compiler can decide whether it's better to use it inlined or not, macros are always inlined and therefor may blow up the code without any benefit.
I for myself in case both macro or function is possible for a needed functionality prefer functions. In a case like your 'getmax' sample this is not the best solution since in this case I would have to implement the same function multiple times for any variable type (i.e. once for int, once for float). In this case I prefer using a function template instead of a macro because types are defined (i.e. with your macro you can compare an int with a float, in a function template you can avoid or allow using different types).
So I would implement such a getmax-functionality as a template somehow like this:
template < typename _TYPE >_TYPE GetMax( _TYPE a, _TYPE b ){ return ( a > b ? a : b );} 1:2:3:4:5:
So, in other words I only use macros where they are the only method to simplify things which can't be solved another way. A good example for this is a macro to determine the length of a static C-array, i.e.:
#define SIZEOF_ARRAY( x ) ( sizeof( x ) / sizeof( x[0] ) )double numbers[] = { 1.0, 1.5, 1.8, 2.3, 2.7 };for ( int n = 0; n < SIZEOF_ARRAY( numbers ); n++ ){ cout << numbers[n];} 1:2:3:4:5:6:7:8:
Here it's not possible to implement SIZEOF_ARRAY with only one argument as a function instead of a macro.
ZOPPO
ZOPPO
Author: rwniceing replied at 2024-08-28 01:04:53
For question-1: solved
for question-2
macro is defined on preprocessor from #define, so it will be compiled first before compiling other function or main() code. Right ? Whereever we put #define on the top of c file or bottom of c file, it will be compiled first, Right ?
in otherwords, there is no difference between two methods besides compiling priority, right ?
Why not we put all function code to #define macro instead of inside body ?
It is time to think about preprocessor meaning .
Rwniceing
for question-2
So the macro here is comparable to a inline function
Rwniceing
Expert: Zoppo replied at 2024-08-28 00:49:31
Hi rwniceing,
1.) No, the __cplusplus macro is set when the file is compiled with a C++ compiler, if it is compiled with a C compiler it is not set. This doesn't really depend on the file extension (i.e. it's possible to compile a *.c file with a C++ compiler), usually you define what compiler is used for the files in a make file or, i.e. with VisualStudio, in the project files' properties.
2.) The difference is the first one (the macro) is simply a placeholder for the code defined for the macro so that code is compiled directly at the place where you put the macro. The second one is a function which is put anywhere in the binary and called the same way I told you at http://www.experts-exchange.com/Programming/Languages/CPP/Q_28506245.html#a40287844
So the macro here is comparable to a inline function.
Hope that helps,
ZOPPO
Hope that helps,
ZOPPO
