When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rwniceing
at 2024-08-27 02:20:21
Point:500 Replies:8 POST_ID:829197USER_ID:12079
C++ Programming Language;;C Programming Language
Attached code is a simple tutorial example C++ code for constructor that I have understood it.
The constructor is just for initializing all Class's default parameter before any access, and I know
the Public label in the code that is allowed other external to access Class's stuff that is
different from Private label.
I have seen someone will do the constructor of Class in different ways such as the Method-2
and Method-3 in attached code which is now commented by " /* */"
Question-1: What is different between Method-1 and Method-2 to declare the constructor inside
of Class ?
Question-2 What is different between Method-3 and ( Method-1 and Method-2), at Method-3, it
declare the constructor outside(externally) of Class. Is it because it can allow other external class or
function access to the Class Circle ? But if it is already declared by Public label , why it still need to declare it outside or externally of Class Circle ?
Question-3, Sometimes, "::" always seen , scope operator :: define a member of a class outside the class itself, So it means Circle:Circle meaning other new external member call "Circle" is member of
Class Circle, Right ? If true, could I think it same way or meaning on std::cout (using namespace std) ?
Rwniceing
of Class ?
Rwniceing
#include<iostream>using namespace std; class Circle //specify a class{ private : double radius; //class data members public: Circle() //default constructor {radius = 0;} /* Method-1 */ Circle(double r) //parameterized constructor {radius = r;} /* Method-2 Circle :: Circle(double r){radius = r; } */ /*Method-3 with external code Circle(double); */ Circle(Circle &t) //copy constructor { radius = t.radius;} void setRadius(double r) //function to set data {radius = r;} double getArea() {return 3.14 * radius * radius;} ~Circle() //destructor {}};/*Method-3 with external codeCircle :: Circle(double r) { radius=r;}*/int main(){ Circle c1; //default constructor invoked Circle c2(2.5); //parmeterized constructor invoked Circle c3(c2); //copy constructor invoked cout << c1.getArea()<<endl; //0 cout << c2.getArea()<<endl; //19.625 cout << c3.getArea()<<endl; //19.625 return 0;} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:
Expert: Zoppo replied at 2024-08-27 07:17:43
You're welcome ...
About why Java is still used I think there are two main reasons:
1. There's IMO no other runtime which is implemented on such a wide spreaded hardware devices (beside computers with Linux, Windows, OSx it even runs on things like routers, smartphones, MP3 players, watches, in cars, lot's of more), there's nearly nothing which is any kind of computer where no JVM exists for so it's one of the most real platform independant languages.
2. It's an easy and clear designed OO language for beginners to learn object orientated programming without need to fight with C++ stuff like pointers, memory allocation, build chains (compiling and linking), maybe more, so it's often used for educational reasons.
To be honest I for myself don't really like Java allthough I know it's powerful and even has some neat features which aren't possible in C++ (because Java instead is some kind of mixed compiled and interpreted) I more like to work with C++ which nearly doesn't have any restrictions (i.e. I hate it lot's of Java classes are 'final' so it's not possible to derive from them).
But this is just my opinion ...
Best regards,
ZOPPO
Best regards,
ZOPPO
Author: rwniceing replied at 2024-08-27 06:59:06
Thanks for your detailed reply.
Last Optional question or advice.
I am doing a lot, php, javascipt(jquery) programming, but those are interpreted language for web browser. If we are going to develope some web application, I think node.js and javascript ,php is good enough . Java runtime installed on client server or user PC can be replaced by node.js which is written in C++ and also browser javascript engine is also written in C++ such as chrome V8 engine , so I don't know why Java programming is still existing if you can be familar with C, C++,C# with php, javascript, node.js, jquery, HTML5 and those code is open source ? the reason of java is still being used that I think it is history for java, a lot application is based on java with its commercial proprietary.
So I guess I am going to go back or spend more time on C, C++ and C# from tutorial and give up java programming which its source is NOT open source to public. For example, you can find a lot of most updated open source HTML5 javascript Game code but for java Game code is really outdated you can find on internet.
Expert: Zoppo replied at 2024-08-27 06:31:10
:o)
Inlining in C++ means something quite different (in short):
After compiled a normal function is a chunk of machine code instructions somewhere in the memory. Whenever such a function is called from elsewhere a lot of things happen, i.e. CPU registers need to be saved before and restored after the function is called. In case the called function as in your sample only calls a simple assignment from one double to another this function calling overhead most probably takes more time than the assignment functionality itself.
Therefore C++ introduced inline function (http://en.wikipedia.org/wiki/Inline_function). If a function is inlined the compiler simply replaces the function call with the body of the function.
If i.e. you have a code like this:
the compiler would treat it somehow like in this (pseudo-code) if Circle::SetRadius is not inlined
c.Circle::Circle(); // Call the default constructor; c.Circle::SetRadius( 1.5 ); // call the function 1:2:
But if the SetRadius is inlined it would do something like this:
c.Circle::Circle();" // Call the default constructor;" c.m_radius = 1.5;" // use function's code inline 1:2:
The latter one does usually consume much less CPU cycles since instead of two function calls only one function call is executed.
ZOPPO
ZOPPO
Author: rwniceing replied at 2024-08-27 06:16:36
as I know inline as CSS style on tag such as <a style='font-size'></a> that is inline style which is not from CSS file
Zoppo, what you mean, "inline" for C++?
Expert: Zoppo replied at 2024-08-27 05:57:50
Question 1: The only possible difference between the two methods is whether the constructor is a inline function or not (as long as you don't use 'inline' explicit it's the choice of the compiler whether a function is inline or not).
In these two cases the constructor can be inline:
// declared and implemented within the classclass Circle{ ... Circle( double radius ) { m_radius = radius; }};// declared in a class, implemented outside of the class in the same fileclass Circle{ ... Circle( double radius ) ;};Circle::Circle( double radius ) { m_radius = radius; } 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:
So there's no difference between these two methods.
If you implement the function in another file than where it's declared it's (most probably) not possible to have it as an inline function:
// declared in a header fileclass Circle{ ... Circle( double radius ) ;};// implemented in a cpp fileCircle::Circle( double radius ){ m_radius = radius;} 1:2:3:4:5:6:7:8:9:10:11:12:
About 2.: I meant there's no difference regarding the functionality. It's just common to keep the implementation outside of the classes in order to keep the class declaration clear and readable. Next the developer has to decide where to implement such functions. Usually small, fast functions are implemented in the header to allow them to be inline, larger, time consuming functions (where inlining has no significant effect) are implemented in a CPP file outside of the header. This usually is a good compromise between runtime-performance and compile-time.
For example with such a circle class it's a good idea to have the 'SetRadius' function within the class or at least within the header to allow it to be inlined because it's just a single assignment and calling it as a none-inline function is much overhead. But if you i.e. want to implement a function which determines whether to circles intersect and, if so, calculates the intersection points it's usually better to move it into a CPP file since such a function is much larger (needs more compile time when it's included in multiple other files) and the calling overhead used for none-inlined functions is most probably very small compared to the time the function needs to do its work.
Author: rwniceing replied at 2024-08-27 05:40:50
Question-1
I am asking
/* Method-1 */
{radius = r;}
/* Method-2
Is method -1 no different from Mehtod-2 ?
Question-2,
Your answer is no difference, besides compiler time, why programmer prefer to declare it externally? It seems it can be controlled easily, somehow in programming since the class may not in the same main file or they are in header file.
Rwniceing
I am asking
/* Method-1 */
{radius = r;}
/* Method-2
Question-2,
Rwniceing
Expert: Zoppo replied at 2024-08-27 04:41:13
Additional info about copy-constructor - as told it's called in two cases:
Circle c;
Circle c1( c ); // first case
Circle c2 = c; // second case
There's a third case which looks quite similare to the second one:
Circle c3;
c3 = c;
That's a bit suprising because in this case the copy constructor is not called, instead the default constructor is called in the first line, in the second one a (maybe implicit generated) assignment operator is called.
From my experience it is a good practice to implement it somehow like this:
class Circle
Circle& operator = ( const Circle& src ) // assignment operator
m_radius = src.m_radius;
return *this;
Circle( const Circle& src ) { *this = src; } // copy constructor
This has the advantages that all of the above shown cases call the same assignment operator and, i.e. if a new member is added it doesn't need to be handled twice in the copy constructor and the assignment operator.
ZOPPO
Circle c;
Circle c3;
c3 = c;
class Circle
return *this;
ZOPPO
Expert: Zoppo replied at 2024-08-27 04:33:36
Hi rwniceing,
about 1.: the comments already describe the kind of constructors:
- Circle() is a default contrustor which is needed to initialize default values some simple call like
Circle c;
- Circle( double r ) is a specialized constructor which implements a convenient way to initialize values.
For example it's easier/nicer to write
Circle c(1.5);
instead of
Circle c;
c.setRadius( 1.5 );
- Circle(Circle &t) is a copy constructor which copies values from a given instance to the new created one whenever one of these calls are used:
Circle c1( c );
Circle c2 = c;
about 2.: There's no (real) difference between implementing a function within a class where it's declared or to declare it in the class and implement it outside, i.e.:
class X
void foo() { /*do something*/ } // declared and implemented at one place
void bar(); // declared here, implemented outsied
void X::bar() // implementation
It's common to implement (at least larger) functions outside of the class declaration to keep that declaration small. It's even very common to move the implementation out of the header i.e. into a .cpp because it saves compile time (exceptions are inline functions and templates, they need to be implemented within the file where they're declared).
about 3.: Whenever you need to 'tell' the compiler something (like i.e. a function or a static variable) belongs to a class which is declared elsewhere you need to prefix it with the class name scope (in your example the 'Circle::').
This is because it maybe another class even declares and implements a function 'Circle' so the compiler wouldn't know which function belongs to which class.
Hope that helps,
ZOPPO
Circle c;
Circle c(1.5);
instead of
Circle c;
c.setRadius( 1.5 );
Circle c1( c );
Circle c2 = c;
class X
Hope that helps,
ZOPPO
