When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rwniceing
at 2024-08-27 00:08:57
Point:500 Replies:13 POST_ID:829196USER_ID:12079
C++ Programming Language;;C Programming Language
When we read the tutorial for pointer in C++ on internet articles, most likey, swap example will be used,
for example,
for example,
#include <iostream>using namespace std;void swap(int *a, int *b){ int temp = *a; *a = *b; *b = temp;}int main() {int x = 42;int y = 17;swap(x, y);cout <<x << '';//17cout <<y << '';//42return 0;} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:
Probably it use swap the pointer to address's vaue to achieve the swapping.In other words, swap thier value. I want to know could we do it in other way, swap the pointer to address instead of its value ?
For example , before swap
&"x //address of x =FFAA00 and its value=42
&"y /address of y =BBCC00a and its value=17
after swap
&"x //address of x =BBCC00 and its new value=17
&"y /address of y =FFAA00 and its new value=42
Or I need to think about to do that using pointer of pointer
Rwniceing
Expert: Zoppo replied at 2024-08-27 01:48:32
If you don't know yet I would suggest to work through this tutorial: http://www.cplusplus.com/doc/tutorial/pointers/
It includes nearly everything one needs to know about pointer including pointer-to-pointer and pointer-to-function concepts.
Author: rwniceing replied at 2024-08-27 01:43:41
thanks for your, Zoppo, I will digest it with cout<< <<endl testing with that.
My goal of this topic is knowing more actual concept for pointer and basic C++ with its syntax
Expert: Zoppo replied at 2024-08-27 01:19:26
Well, you know pointers are nothing else than some kind of integer values holding the address of a variable of a given type. If an address is assigned to a pointer (i.o.w. changing the value of the pointer) the pointer type needs to be the same, so you can't i.e. simply assign a pointer to float to a pointer to int.
In your sample the new value 0x1234 is of type int, so it needs to be type-casted to a pointer to int because the compiler doesn't allows assinging anything else than a pointer.
Author: rwniceing replied at 2024-08-27 01:03:45
Thanks for your reply. If possible, could I know what is that pointer declaration meaning of
int *ptr = (int *) 0x1234; ?
what is (int*) stand for that always seen in tutorial articles on internet?
Rwniceing
Rwniceing
Expert: Zoppo replied at 2024-08-27 00:53:51
Yes, exactly.
Author: rwniceing replied at 2024-08-27 00:36:23
in other words,
int x=42 which is initialized by the computer complier and assign its address and users could
NOT be able to assign it , Right ? for exmple,
&x=BBCC00;// that is not working..
Author: rwniceing replied at 2024-08-27 00:33:08
steve, thanks for your reply, reported it in my previous post
Expert: stevejacob68 replied at 2024-08-27 00:31:47
There is a error in calling of swap function in main (),
You need to specify the address of variable instead of its value.
change swap(x,y); line
with swap(&x,&y);
In swap(&x,&y), address of X and Y is passed instead of its value.
with swap(&x,&y);
Expert: Zoppo replied at 2024-08-27 00:31:23
350 points EXCELLENT
I still don't know what's you're goal, but here something you should keep in mind:
Every variable (at least nearly every, it's i.e. different for 'register' variables) is some kind of placeholder of an address, when the compiler creates the binary code it decides where to put a variable (local variable commonly are put on the stack, occurances use the current stack pointer + offset to the local variable).
This means the address of the variable is kind of hardcoded in the binary, there's no way to change it.
Author: rwniceing replied at 2024-08-27 00:23:54
Sorry again, it is swap(&x, &y);
I know swap is successful to swap their value,
I just think could I do it in other way to complete the same function
Now it is swapping to their value. Could I swap their address instead of value to acheive the same thing ?
ozo, probably, yes, the address is static at the beginning at &x and &y when iniitializing, how about other experts' comment ?
Expert: Zoppo replied at 2024-08-27 00:21:33
Hi rwniceing,
since (as ozo wrote) this is not possible I'd like to ask why do you want to do this? Could you explain what you want to achieve?
ZOPPO
ZOPPO
Author: rwniceing replied at 2024-08-27 00:21:28
Sorry typing mistake , it should be swap(&a, &b);
#include <iostream>using namespace std;void swap(int *a, int *b){ int temp = *a; *a = *b; *b = temp;}int main() {int x = 42;int y = 17;swap(&x,& y);cout <<x << '';//17cout <<y << '';//42return 0;} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:
ozo, you know what I'm asking ?
Expert: ozo replied at 2024-08-27 00:19:06
150 points EXCELLENT
int x = 42;
int y = 17;
declares &x and &y as fixed positions in memory which cannot be changed
int y = 17;
