When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by BobCSD
at 2024-08-25 18:59:21
Point:500 Replies:9 POST_ID:829194USER_ID:12080
Cascading Style Sheets (CSS);;.NET
I have a style that makes my grid row 34px high. But if the text wraps on two lines, it leaves too much linespacing between the lines.
How do I make my grid row height 34px, but make my linespacing 14/14.
thanks!
thanks!
.RadGrid_RTOGrid, .RadGrid_RTOGrid .rgMasterTable, .RadGrid_RTOGrid .rgDetailTable, .RadGrid_RTOGrid .rgGroupPanel table, .RadGrid_RTOGrid .rgCommandRow table, .RadGrid_RTOGrid .rgEditForm table, .RadGrid_RTOGrid .rgPager table { font-weight: 100; font-size: 14px; line-height: 34px; font-family: Tahoma, "Segoe UI",Arial,Helvetica,sans-serif; } 1:2:3:4:5:6:
Author: BobCSD replied at 2024-09-07 02:15:55
None of the suggestions worked. Found a solution from telerik.
Author: BobCSD replied at 2024-09-02 11:40:11
that did not work. I wrote telerik and asked for help on this and this is the result of what works.
I had to set the line height to 15px to make the word wraps not have gaps between them, then to make a minimal row height, I had to add padding on each row and header as below:
.RadGrid_RTOGrid, .RadGrid_RTOGrid .rgMasterTable, .RadGrid_RTOGrid .rgDetailTable, .RadGrid_RTOGrid .rgGroupPanel table, .RadGrid_RTOGrid .rgCommandRow table, .RadGrid_RTOGrid .rgEditForm table, .RadGrid_RTOGrid .rgPager table { font-weight: 100; font-size: 14px; line-height: 15px; /* so won't be gappy on line breaks */ font-family: Tahoma, "Segoe UI",Arial,Helvetica,sans-serif; }/* remove the gaps between line breaks, but keep height consistent */div.RadGrid_RTOGrid .rgRow td,div.RadGrid_RTOGrid .rgAltRow td { padding-top: 10px; padding-bottom: 10px;}div.RadGrid_RTOGrid .rgHeader { padding-top: 10px; padding-bottom: 10px;}.RadGrid_RTOGrid .rgHeader, .RadGrid_RTOGrid .rgHeader a { color: black; font-weight: bold; font-size: 12px; line-height: 15px; /* so won't be gappy on line breaks */} 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:
Expert: rwniceing replied at 2024-08-27 11:08:44
.test{
font-size:14px;
line-height:28px;
border-color:#FFFFFF;
border-style:solid;
border-width:3px;
you can put the code above for your class style, you will know what I say. If not, please send us your html page with css file, and show us what you expect before or after(even this is not what you expect, but at least, we know what is problem there).
You can put it in http://jsfiddle.com or http://jsfiddle.net website , others are able to read it
font-size:14px;
line-height:28px;
border-style:solid;
border-width:3px;
Author: BobCSD replied at 2024-08-27 11:02:38
k*px(space)+14px(font-size)+k*px(space)=b*px
Can you please convert the above into a language I can understand?
Please just tell me what it would be for 14/14 line spacing with 34 minimum height on the panel, but center the text vertically in the panel.
thanks!
thanks!
Expert: rwniceing replied at 2024-08-26 20:41:45
where b, word spacing, can be anything you want by k change
So read my previous post and set each side of border color can be different by CSS if need .
Rwniceing.
Rwniceing.
Author: BobCSD replied at 2024-08-26 10:37:21
Above you see the User Name field. It wraps. I don't want that big gappy space between words. On average the line height should be 34. I don't want it tight like 14/14. It needs to minimum be 34px. It can go larger if the row wraps. It doesn't have to stay at 34px. But I don't want the wrap to be gappy.
Hope that helps.
'Thanks!
Expert: rwniceing replied at 2024-08-25 21:53:34
Dear Author,
you could set line-height to 7px(space)+14px(font-size)+7px(space)=28px for the spacing between word to word equal to 14px if word wrapped.
But when you set the row height = 34px, the second word-wrap line will overflow the row. So, I suggest this if you have to keep row height 34px; don't set row height let it auto adjust and put row white-color border-width with 3px to simulate row height to be 34px and if word wrapped, the line to line or word to wrod spacing is also keeping 14px;
.test{font-size:14px;line-height:28px;border-color:#FFFFFF;border-style:solid;border-width:3px;} 1:2:3:4:5:6:7:
If you send us the complete or portion of html page with css , it will be easier to understand your question
Rwniceing
Author: BobCSD replied at 2024-08-25 19:37:22
I need more assistance... what I did is not working... Please provide me with the proper elements. thanks!
font-weight: 100; font-size: 14px; min-height: 34px; font-family: Tahoma, "Segoe UI",Arial,Helvetica,sans-serif; 1:2:3:4:
Expert: Gary replied at 2024-08-25 19:29:24
Don't apply the line-height attribute but set the row/cell height attribute and leave the line height as it normally is.
