When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rwniceing
at 2024-08-22 07:05:46
Point:500 Replies:10 POST_ID:829190USER_ID:12079
JavaScript;jQuery;Asynchronous Javascript and XML (AJAX)
For setTimeinterval() that can do callback function such as
window.setInterval(displaymesg,2000, "message is here");function displaymesg(mesg){document.getElementById("message-wrapper").innerHTML+= mesg;} 1:2:3:4:
The code above is working for all browsers except older version of IE browser.
The question is
1-it works for the browsers becoz they are using javascript closure to pass argument to the callback function, Right ?
2- it didn't work for IE old browser bcoz they did NOT use javascript closure to do that ,Right?
3- If item-1 is correct, they are using similar or concept closure javascript code as follows, Right ?
var displaymesg=closurefunc("message is here");"window.setInterval(displaymesg,2000);"function closurefunc(mesg){ function callbackfunc(){ document.getElementById("message-wrapper").innerHTML+=mesg;"}return callbackfunc;"} 1:2:3:4:5:6:7:8:
Or there is other method besides closure to pass the argument into callback function ?
Rwniceing
Author: rwniceing replied at 2024-08-22 23:35:02
Thanks for all of reply
Answer to Question on the topic post
1-NO, there is no need to use closure to do the setInterval() for those browser works for setInterval since it is specified from http://www.w3schools.com/jsref/met_win_setinterval.asp and from from pre ECMA standards
2-Yes, for IE laterst version, setInterval is not working since IE is not support passing back the callback argument, we can use the closure to solve it as previous code attached OR use other technique such as IE-specific compatibility code found from https://developer.mozilla.org/en/docs/Web/API/window.setInterval
3- Correct and if IE laterst version is not working for setInterval, or read item-2 above
Expert: Rob Jurd replied at 2024-08-22 23:16:25
125 points EXCELLENT
Older versions you can, new versions do not. You can't pass the variable the way you were going.
What you've assumed above is correct
Author: rwniceing replied at 2024-08-22 22:26:13
In other words,
2-Yes, for old browser such IE older version, setInterval is not working since IE is not support passing back the callback agrument, we can use the closure to solve it as previous code attached OR use other technique such as
3- Correct, if IE is not working for old browser for setInterval, or read item-2 above
I think I concluded those my question with the the asnwer above that is okay, Right ?
Finally question is I heard some IE is not working setInterval with passing argument, Is it right for older version of IE or latest version of IE ? I 'm confusing that.
Expert: Rob Jurd replied at 2024-08-22 19:04:17
Callback Arguments:
https://developer.mozilla.org/en/docs/Web/API/window.setInterval#Callback_arguments
Note that passing additional parameters to the function in the first syntax does not work in Internet Explorer 9 and below. If you want to enable this functionality on that browser you must use a compatibility code (see the Callback arguments paragraph).
Callback Arguments:
Expert: Rob Jurd replied at 2024-08-22 18:58:37
Any questions let me know
Expert: Rob Jurd replied at 2024-08-22 18:58:18
Not so much to do with closure but as Gary indicated about how the browsers interpreted the pre ECMA standard, so their implementation was different.
To reiterate Gary's code
var msg = "message is here";window.setInterval(function() { displaymesg(msg);},2000);function displaymesg(mesg){ document.getElementById("message-wrapper").innerHTML+= mesg;}; 1:2:3:4:5:6:7:8:
#a40278995 There is no closure here. The setInterval function is defined as:
Mozilla: https://developer.mozilla.org/en/docs/Web/API/window.setInterval, which talks about how closures are avoided
Author: rwniceing replied at 2024-08-22 07:48:39
Gary, your code seems different from window.setInterval(displaymesg,2000, "message is here");
If you code is corrrect, we don't need to use closure on setInterval since it can pass
"msg here" into displaymesg function argument directly from your code without any closure code help, Right ? If so, the item-1 question is not correct .
Expert: Gary replied at 2024-08-22 07:45:23
setInterval (and the similar setTimeout) are from pre ECMA standards, so browsers could interpret and implement them however they liked
These days all browsers operate (almost) to the ECMA standards
I don't have time to find the docs on it at the mo.
Author: rwniceing replied at 2024-08-22 07:31:07
Gary, you mean
1-Yes,
2-Yes, old browser did not use closure
3-Yes, similar concept code as attachment above(just for concept only)
All "yes" ,Right ?
Last question before closing this thread , why older browser didn't use closure ? Is it becoz closure feature implemented in latest version of browser from suggestion from latest ECMA script specification ?
In other words, in the past there is no closure concept or thing in javascript
1-Yes,
All "yes" ,Right ?
Expert: Gary replied at 2024-08-22 07:18:54
Correct
