When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-31 08:37:25
Point:500 Replies:9 POST_ID:829187USER_ID:11059
Linux;Windows 7;Web Browsers
Today I go to yahoo,com that has advertisting, of course since business sector, we are considerate.
But when I go to yahoo's email website. The ad is going to the top of email box with a little
small Horizontal bar, it is always switching to other ad. That is I am hard to believe it from yahoo
And a lot website has a lot contiuning ad.
Ad is okay but it is at top,left,right,bottom, z-index-1,z-index-999 like CSS3 that is hard to believe
How to block them from browser setting besides using proxy server service and php scripting
Expert: eenookami replied at 2024-08-29 23:54:20
Force accept
eenookami
CS Moderator
eenookami
CS Moderator
Expert: gheist replied at 2024-08-25 22:07:09
#a40232066 and #a40233007 are both valid answers (first is more popular solution), but lets wait for a week or so for asker to come back ?
Expert: Netminder replied at 2024-08-25 20:19:00
The objection filed has stopped the automated closing of this question.
Experts,
If you feel that one or more of the comments should have led to a solution to the problem, please post the ID of the comment. If there are no responses from the Experts, we will assume that there is no solution posted, and will delete the question in about four days.
Thanks,
Netminder
Senior Admin
Experts,
Thanks,
Netminder
Senior Admin
Expert: ThomasMcA2 replied at 2024-08-25 07:55:10
Wow, a user saying they will test an offered solution now generates an administrative deletion?
Amazing.
Amazing.
Expert: LeeTutor replied at 2024-08-24 09:37:42
Thanks for your reply. I need to use or test it for a while, and reply your post within 2-3 days. Now at least, it is possible.
Expert: gheist replied at 2024-07-31 14:44:53
another is disconnect.me, and you can have both
Author: duncanb7 replied at 2024-07-31 09:07:44
Expert: ThomasMcA2 replied at 2024-07-31 09:05:56
Use a browser add-on called Adblock Plus.
