When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by SheppardDigital
at 2024-07-31 03:37:48
Point:500 Replies:12 POST_ID:829183USER_ID:12072
Linux;;
I have a VPS running Centos 6.4 and WHM 11.44.1
Yesterday I started receiving emails saying that the named service had failed and couldn't be restarted.
When attempting to start the server I get the following
In an attempt to fix the issue I've updated WHM to the latest version and ran the command /scripts/fixrndc as described on various websites on the internet, but it still doesn't seem to resolve the issue.
I'm hoping someone will be able to help me fix this issue.
Starting named: /etc/init.d/named: line 97: 28896 Aborted /usr/sbin/named-checkconf $ckcf_options ${named_conf} > /dev/null 2>&1
Error in named configuration:
/etc/named.conf:4: unknown key 'rndc-key'
/etc/rndc.key:1: key '': bad key name
mem.c:1246: REQUIRE(ctx->references == 1) failed, back trace
#0 0x7fce761546c6 in ??
#1 0x7fce7615489a in ??
#2 0x7fce761667a2 in ??
#3 0x403571 in ??
#4 0x7fce7499bd1d in ??
#5 0x4025d9 in ??
#3 0x403571 in ??
#5 0x4025d9 in ??
Expert: duncanb7 replied at 2024-07-31 09:29:18
thx for yr pt
ve a nice day
duncan
ve a nice day
duncan
Author: SheppardDigital replied at 2024-07-31 09:28:09
This resolved my issue, although I had to remove the options section from the generated rndc.key
Expert: gheist replied at 2024-07-31 04:57:51
On normal centos it generates absent rndc.conf when starting
Expert: duncanb7 replied at 2024-07-31 04:36:45
it seems the rndc.key issue.
Please take a look on how to generate rndc.key file at his article ,
http://tecadmin.net/configure-rndc-for-bind9/
Author: SheppardDigital replied at 2024-07-31 04:29:36
Just to add, I've tried renaming the rndc.conf file and running the /scripts/fixrndc commend, but again, it doesn't generate a key.
Author: SheppardDigital replied at 2024-07-31 04:15:59
If it helps, this is the content of /etc/rndc.conf
and this is the top of the file /etc/named.conf
include "/etc/rndc.key";controls { inet 127.0.0.1 allow { localhost; } keys { "rndc-key"; };};options { /* make named use port 53 for the source of all queries, to allow * firewalls to block all ports except 53: */ // query-source port 53; /* We no longer enable this by default as the dns posion exploit has forced many providers to open up their firewalls a bit */ // Put files that named is allowed to write in the data/ directory: directory "/var/named"; // the default pid-file "/var/run/named/named.pid"; dump-file "data/cache_dump.db"; statistics-file "data/named_stats.txt"; /* memstatistics-file "data/named_mem_stats.txt"; */ allow-transfer {"none";};}; 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:
It looks to me like rdnc-key isn't defined in the rndc.conf file. I guess this is causing the problem, but how do I re-create that key?
Author: SheppardDigital replied at 2024-07-31 04:14:04
I didn't rename any files when I ran /scripts/rebuilddnsconfig
Expert: duncanb7 replied at 2024-07-31 04:12:09
when you rebullid it , did you rename the file /etc/named.conf ?
Author: SheppardDigital replied at 2024-07-31 04:02:03
whm/cpanel
Expert: duncanb7 replied at 2024-07-31 04:00:25
you are using cpanel, right ?
Author: SheppardDigital replied at 2024-07-31 03:52:59
During the rebuild it tries to restarted named and I get the same error as above.
Expert: duncanb7 replied at 2024-07-31 03:44:00
Are you using cpanel?
If so, try it ,rebulid the /etc/named.conf file, it may work
