When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
at 2024-07-31 00:04:13
Point:500 Replies:13 POST_ID:829180USER_ID:11059
Microsoft IIS Web Server;;Windows 7
I've just solved issue about xampp and IIS running on the same computer
http://www.experts-exchange.com/Software/Server_Software/Web_Servers/Microsoft_IIS/Q_28487470.html
So far So good, when type "localhost" it will go to c:inetpubwwwrootiisstart.htm
Now I change 'applicationHosts.config file to change the document default path from
c:inetpubwwwroot to c:xampphtdocs and I copy iisstart.htm to c:xampphtdocs
Okay, now I go to type "localhost" it will go my external sites server that is not show iisstart.htm page.
But when I type "localhost/iisstart.htm" which is exactly at c:xampphtdosc that is working,
iisstart.htm is shown, and other typing is also working
type "localhost/iisstart.htm" it is also working
type "localhost?" it is also working
type "127.0.0.1" it is also working
but only both "localhost" and "localhost:80" not working
Now I go to check hosts file at c:windowsystem32driversetchosts in which there is nothing
information about host forwarding to the external site.
when type other file such as "localhost/data/php/index.html" that also works that is
matched to file at c:xampphtdocsdataphpindex.html
So the question, why it happen, who get the final right or owner for the name of "localhost" ?
localhost:8001 forwarding to my xampp web server that works as usual
I try to turn off xampp , it did NOT solve my issue
So I believe there is some conficit, "localhost" can NOT resolve its final destination.
how to translate "localhost" to final IP on brwoser
Expert: Joseph O'Loughlin replied at 2024-07-31 12:15:14
Both the hosts file and DNS are used to translate human readable names like
www.purple.com
into ip addresses that the computer and network can use.
Hosts files pre-dated dns. The last time I used a unix system that relied purely on a hosts file was in 1988.
I am using an obsolete tool that uses the trident web browser engine internally but the vendor's site is down. Rather than display erroneous information from that site, I added
127.0.0.1 www.vendor.com
to the hosts file
and am happy about getting no response on a machine hosting iis rather than the placeholder page.
www.purple.com
to the hosts file
Author: duncanb7 replied at 2024-07-31 01:24:31
Thanks for your reply , as we know it is sometimes hard to find the exact root cause for browser issue
Anyway, if possible, please write about the hosts file quesiton in my last post if have time
Author: duncanb7 replied at 2024-07-31 01:22:09
I disable and enable setting of "Bulit-in Asynchronous DNS" that is not solvign the issue
Since Chrome will use setting from IE from the link above mentioned, so I try to
reset its default and clear up all browser data from IE and Chrome.
Now it works and page from typing "localhost" is shown up. it is fixed.
So I agree with you that the new version browser should already fix the localhost issue, but
it has other issue, Anyway it is fixed even I don't know what is exact root cause.
Probably it is not related to proxy since IE and FF works before and after
Even I change the hosts with or without
127.0.0.1 localhost
::1 localhost
it also work . It seems two sentences in hosts file is not reacted at all , Why ?
If that not react ,how all browsers could resolve localhost to 127.0.0.1 ?
Please advise the final question if possible
DUncan
127.0.0.1 localhost
::1 localhost
DUncan
Author: duncanb7 replied at 2024-07-31 01:02:39
but it is very interesting when type localhost? it work and go to
localhost/? and show the pages but "localhost" still not working
Author: duncanb7 replied at 2024-07-31 00:58:25
I don't any proxy, all is auto connection
I quote or unquote
# 127.0.0.1 localhost
# ::1 localhost
or
127.0.0.1 localhost
::1 localhost
Both cases are not working after quite and restart chrome
winlogo+k both keys can not go to any window or menu
I quote or unquote
# ::1 localhost
or
127.0.0.1 localhost
::1 localhost
# Copyright (c) 1993-2009 Microsoft Corp.## This is a sample HOSTS file used by Microsoft TCP/IP for Windows.## This file contains the mappings of IP addresses to host names. Each# entry should be kept on an individual line. The IP address should# be placed in the first column followed by the corresponding host name.# The IP address and the host name should be separated by at least one# space.## Additionally, comments (such as these) may be inserted on individual# lines or following the machine name denoted by a '#' symbol.## For example:## 102.54.94.97 rhino.acme.com # source server# 38.25.63.10 x.acme.com # x client host# localhost name resolution is handled within DNS itself.# 127.0.0.1 localhost# ::1 localhost#.10.2 google.com 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:
Expert: Joseph O'Loughlin replied at 2024-07-31 00:52:21
It's not the problem you found, since fixed.
localhost is defined in
c:windowssystem32driversetchosts
please review the content of that file.
What are your proxy settings? Are they set to be configured automatically, as this mechanism can set other behaviours?
Author: duncanb7 replied at 2024-07-31 00:42:37
Version 36.0.1985.125 m
Expert: Joseph O'Loughlin replied at 2024-07-31 00:37:07
What version of Chrome are you using? It's unusual to be using an old version because of it's integrated update mechanisms.
Author: duncanb7 replied at 2024-07-31 00:33:31
I found similar issue at this chrome site at
https://code.google.com/p/chromium/issues/detail?id=224215#c2
it seems it is related to how chrome resolve localhost to 127.0.0.1 from DNS
Expert: Joseph O'Loughlin replied at 2024-07-31 00:27:00
On my machine localhost in chrome works, so I suggest you contrast what proxy is set by running (Windows key+R) inetcpl.cpl, click on the connections tab, Lan Settings.
It takes a bit of work to get Chrome not to use the system proxy
http://www.walkernews.net/2008/11/07/how-to-configure-or-disable-google-chrome-proxy-server-settings-independently/
I would be suspicious that one of your plugins into Chrome or a 3rd party system utility is providing services via localhost
check at the command prompt using NETSTAT
looking for your hostname or 127.0.0.1
that somehow interfere
It may be possible to infer the service from the port numbers used
Author: duncanb7 replied at 2024-07-31 00:15:41
After checking, it is NOT working for "localhost" on chrome only
both FF and IE is working with typing "localhost"
So it must be related to how chrome to decode "localhost"
How to fix this ?
How to fix this ?
Author: duncanb7 replied at 2024-07-31 00:13:53
please review my question becoz of new editing before your post sent
http://localhost is also NOT working
it is related to how browser interpret the localhost name
Expert: Joseph O'Loughlin replied at 2024-07-31 00:10:32
I would expect this behaviour.
Originally web servers if only given a path would load index.html or index.htm from that folder.
When Microsoft offered Active Server Pages they added default,asp then default.aspx
however iisstart is a placeholder, not a default page for a folder, and is set by other internet information server configuration files.
http://localhost is just a link to the webserver's / folder.
