When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by grasslime
at 2024-07-30 20:35:47
Point:500 Replies:7 POST_ID:829179USER_ID:12019
jQuery;;
i am trying to make the clicked link background color to blue and other links to white.
its not working. pl help.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head><meta http-equiv="Content-Type" content="text/html; charset=utf-8" /><title>Untitled Document</title><script src="http://ajax.googleapis.com/ajax/libs/jquery/1.9.1/jquery.min.js"></script><script>$(document).ready(function() { $( "#country,#game,#drink" ).click(function(){ $("#"+$(this)).css( "background-color", "blue" ); $("#"+$(this)).not().css( "background-color", "#fff" ); });});</script></head><body><ul> <li id="country"><a href="#">country</a></li> <li id="game"><a href="#">game</a></li> <li id="drink"><a href="#">drink</a></li></ul></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:
Author: grasslime replied at 2024-07-31 20:28:31
thanks for additional info on .bind.
can some one provide solution using .not() ?
Expert: duncanb7 replied at 2024-07-31 09:10:40
You could say this method is better than the one in previous post suggested
Because every reply code I tested it on my server .
Expert: Gary replied at 2024-07-31 09:07:57
I didn't say it was deprecated, I said it is not the recommended method and not required in this instance.
Expert: duncanb7 replied at 2024-07-31 08:12:51
Gray,
I can NOT find .bind is depreciated for all jquery versions or latest in google search or in jquery site, I just find this jquery depreicated link at http://api.jquery.com/category/deprecated/
Could you show us .bind is depreciated and not able to used in jquery latest version ?
Expert: duncanb7 replied at 2024-07-31 07:58:12
Thanks your reminder but it works from my jquery library(not too old) , sometimes it is hard to be aware or keep track of any function is depreciated or not from the vendor in any time, I just send the idea to the author about .
if ($(this).text()=="country")$(this).css( "background-color", "blue" );
if ($(this).text()!="country")$(this).css( "background-color", "white" );
Hope you understand it.
Expert: Gary replied at 2024-07-31 07:25:33
400 points EXCELLENT
@Duncan
Stop telling people to use .bind when .on is the preferred method (and .bind may become deprecated) and it is not even needed in this situation.
@grasslime
@grasslime
$(document).ready(function () { $("#country,#game,#drink").click(function () { $("#country,#game,#drink").css("background-color", "#fff"); $(this).css("background-color", "blue"); })}); 1:2:3:4:5:6:
Expert: duncanb7 replied at 2024-07-30 23:04:24
100 points EXCELLENT
you need to use bind() click, try this, it works, change the white color to your white color code if need
duncan
duncan
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml"><head><meta http-equiv="Content-Type" content="text/html; charset=utf-8" /><title>Untitled Document</title><script src="http://ajax.googleapis.com/ajax/libs/jquery/1.9.1/jquery.min.js"></script><script>$(document).ready(function() { $( ".tap" ).bind( "click", function() { // alert( message ); if ($(this).text()=="country")$(this).css( "background-color", "blue" ); if ($(this).text()!="country")$(this).css( "background-color", "white" );});});</script></head><body><ul> <li class="tap" id="country"><a href="#">country</a></li> <li class="tap" id="game"><a href="#">game</a></li> <li class="tap" id="drink"><a href="#">drink</a></li></ul></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:
