When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by ambientsbs
at 2024-07-30 16:06:41
Point:500 Replies:2 POST_ID:829173USER_ID:12065
VB Script;Microsoft Visual Basic.Net;Miscellaneous Programming
Hello Experts!
I have two VBA functions in an Excel file that I'm using to perform two separate operations. They look like this:
Public Sub Cell2Cell(ByRef Source_Range As Range, ByRef Target_Range As Range)Dim i As Integeri = 1For Each c In Source_Range.Cells If IsNumeric(c.Value) Then Target_Range.Cells(i) = c.Value Else Target_Range.Cells(i) = "" End If i = i + 1NextEnd SubPublic Sub Matching_Cell2Cell(ByRef Source_Range As Range, ByRef Crit_Range As Range, ByRef Copy_Range As Range) Source_Range.AdvancedFilter Action:=xlFilterCopy, CriteriaRange:=Crit_Range, CopyToRange:=Copy_Range, Unique:=FalseEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:
I use the first function to copy cells from one cell range to another, but only cells that have a numeric value. In this scenario, I only have one row of cells in a range that I'm copying. What I'm looking to do is combine these two functions into one, where I can basically filter multiple rows, based on a range that defines my filter, and then copy ONLY numeric values to another range where the cells are in a different orientation. I know in advance that my filter would always yield only one row of results.
To give an example, I want to take a range of data like A1:F200, filter that list down to one row based on a filter that would be looking at the data in column A. After my range has been filtered and I have one row of data that sits horizontally from say cells A9:F9 in "Sheet 1" I would like to copy only the numeric data to a range in "Sheet 2" to cells I9:I14.
Can someone please tell me how I would do this? Thank you!
Author: ambientsbs replied at 2024-07-31 15:36:59
Hi Duncan,
Thank you for the response but, unfortunately, I don't think that "record a macro" is the response that I'm looking for. : ) I don't mean to sound rude, so please don't take it that way. It just doesn't seem possible to record what I'm looking to do, where I would change a dropdown that would affect how my rows are filtered and then copy only numeric data to another cell range.
Would it be more helpful for me to attach an Excel document that shows in more depth what I'm looking to do? I need someone to simply tell me how to do what I'm looking to do with code. Thanks again!
Expert: duncanb7 replied at 2024-07-30 19:40:57
Since your need can be done on Excel cell menu tab or click function, so you can do it by Macro Recording.
Did you use "Macro recording" , click tools-Macro->Record macro, and choose saving maco location,
and then click or do any action on Excel cell , for example, drag the range cell and click Excel
tab for autofit tab. Afterwards, all action will be translated into VBA code and save it on the macro
There is MR tutorial at this site ,
http://www.youtube.com/watch?v=nvWpFdo7EO0
If it is not done, please send us your example excel file with data cell examples included with VBA code that will let other experts to understand your quesion easier.
