When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Seamus2626
at 2024-07-30 08:36:40
Point:500 Replies:6 POST_ID:829171USER_ID:11690
I need an amendment to the following piece of code
The copy is a regular paste, i need a paste special
Many thanks
Many thanks
Sub macro()Dim arrData As VariantDim arrTransfer As VariantLastTransferRow = Sheets("Change Summary").Range("A" & Rows.Count).End(xlUp).RowarrData = Join(WorksheetFunction.Index(Sheets("Add Delete Team Members").Range("N15:W17").Value, 1, 0), ";")arrTransfer = Join(WorksheetFunction.Index(Sheets("Change Summary").Range("N" & LastTransferRow & ":A" & LastTransferRow).Value, 1, 0), ";")If arrData = arrTransfer Then Res = MsgBox("This is the same data, are you sure you want to send", vbYesNo) If Res = vbYes Then Sheets("Add Delete Team Members").Range("N15:W17").Copy Sheets("Change Summary").Range("A" & LastTransferRow + 1) Else Exit Sub End IfElse Sheets("Add Delete Team Members").Range("N15:W17").Copy Sheets("Change Summary").Range("A" & LastTransferRow + 1)End IfEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:
Author: Seamus2626 replied at 2024-07-30 09:19:56
Thanks Duncan but It does not work on this code
Put that line into my code where you would put it and i will run
Expert: duncanb7 replied at 2024-07-30 09:10:34
You need to the put the range and sheet you want with this PasteSpeical with values only
.PasteSpecial xlPasteValues
Author: Seamus2626 replied at 2024-07-30 09:07:00
Okay,
So my code picks up range N15:W17 from tab "Add Delete Team Members" and pastes over to tab "Change Summary", it pastes to the next available row after the headings (A1:L1)
When it pastes, its pastes with formats, i do not want the formats, i only want the values
Expert: duncanb7 replied at 2024-07-30 08:53:04
Could you write your question in detail , what you want which sheet which range or cell to get pasteSpecial and what format for the paste you want ?
duncan
duncan
Author: Seamus2626 replied at 2024-07-30 08:49:46
Hi Duncan,
I dropped that in and got the error message
"Invalid use of property" on line xlPasteValues
Sub New_Staff()Dim arrData As VariantDim arrTransfer As VariantLastTransferRow = Sheets("Change Summary").Range("A" & Rows.Count).End(xlUp).RowarrData = Join(WorksheetFunction.Index(Sheets("Add Delete Team Members").Range("N15:W17").Value, 1, 0), ";")arrTransfer = Join(WorksheetFunction.Index(Sheets("Change Summary").Range("N" & LastTransferRow & ":A" & LastTransferRow).Value, 1, 0), ";")If arrData = arrTransfer Then Res = MsgBox("This is the same data, are you sure you want to send", vbYesNo) If Res = vbYes Then Sheets("Add Delete Team Members").Range("N15:W17").Copy Sheets("Change Summary").Range("A" & LastTransferRow + 1).PasteSpecial xlPasteValues Else Exit Sub End IfElse Sheets("Add Delete Team Members").Range("N15:W17").Copy Sheets("Change Summary").Range("A" & LastTransferRow + 1).PasteSpecial xlPasteValuesEnd IfEnd Sub 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:
Expert: duncanb7 replied at 2024-07-30 08:42:48
You can try this,
OR
Sheets("Change Summary").Range("A" & LastTransferRow + 1).PasteSpecial xlPasteFormats
OR
