When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by dgravitt
at 2024-07-30 08:25:36
Point:500 Replies:9 POST_ID:829170USER_ID:12063
Microsoft Access Database;;
I have a string "115 CS 575840" that I need to return the 6 numbers that are together. So, from this string I need to return 575840.
Expert: Rey Obrero (Microsoft Access MVP) replied at 2024-07-30 09:25:51
dgravitt,
cool, but next time, it will be helpful if all scenario about the data is available.
Author: dgravitt replied at 2024-07-30 09:22:11
I found a work around to handle the records where it just contained 6 numbers, and Rey, your solution handled the rest.
Expert: duncanb7 replied at 2024-07-30 09:07:23
If always next to "CS"
=MID(A1,FIND("CS",A1)+3,6)
Author: dgravitt replied at 2024-07-30 09:03:00
CS is not always part of it
Author: dgravitt replied at 2024-07-30 08:56:43
Rey, yours works well except the case where there are only 6 numbers in the field. Then it returns an error.
Author: dgravitt replied at 2024-07-30 08:52:35
The 6 numbers could be at the end, beginning or middle. I need to pull out the 6 no matter where they are.
Expert: Rey Obrero (Microsoft Access MVP) replied at 2024-07-30 08:49:51
this should do it
trim(mid(yourString,instrrev(yourString," ")))
Expert: Iammontoya replied at 2024-07-30 08:36:41
if your last numbers are always six digits you can try this:
=NUMBERVALUE(RIGHT(B3,6))
this takes the text in column B3 and takes the 6 digits from the end, and converts them to a number value
Expert: duncanb7 replied at 2024-07-30 08:34:35
Is it what your want ?
MID(yourtext,LEN(yourtext)-5,6)
