When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by JG_L
at 2024-07-30 07:06:46
Point:500 Replies:5 POST_ID:829168USER_ID:12061
Computer Servers;Networking Hardware;Windows Networking
I am trying to find out what it means for a NIC to be in a "Dead/Alive" state.
Expert: John Hurst replied at 2024-08-02 10:58:17
So then as I said above (and others noted later) that the NIC is not functional (dead) or functional (alive).
Author: JG_L replied at 2024-08-02 10:45:11
I am sorry, I think I misunderstood something about this term. It was indicating dead OR alive, which makes sense of course - not dead-alive. I am sorry to have wasted people's time. Thank you very much for your responses though.
Expert: Razmus replied at 2024-07-30 08:01:20
I have to admit to being confused by the question as well. I normally think of functional NIC in three possible states:
Alive or active - The NIC is seeing and passing traffic.
Inactive - The NIC is not-disabled, but is not seeing or passing traffic. This would normally be because there is no media connected or no wireless network available.
Disabled - The NIC is disabled, in hardware or by the OS.
I suppose 'Dead' could refer to either Inactive or Disabled NIC, but it's also possible that a 'Dead' NIC could refer to a NIC which is physically broken or for which the relavent operating system lacks proper drivers to interface with the card.
Expert: duncanb7 replied at 2024-07-30 07:31:40
I think it is just referring or related to the NIC card or adapter is connected or disconnected from the line (Alive/Dead), otherwise it is hard to find its definition in google search.
Could you provide more information ?
Expert: John Hurst replied at 2024-07-30 07:10:23
Can you provide a context? I have not seen such a setting. A NIC can be dead (not functional) or alive (working).
