When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Dinesh Kumar
at 2024-07-30 06:42:20
Point:500 Replies:18 POST_ID:829167USER_ID:12059
jQuery;JavaScript;C# Programming Language
I want to deselect all radion button except the current selected one
This is the code I am trying:
<script type="text/javascript">
function handle(myRadio) {
$(this).checked = "checked";
$("#abc :radio").each(function () {
if (document.getElementById('myRadios').checked != "checked") {
$("#abc").find('input[type=radio]').not(this).prop('checked', false);
</script>
<div id="abc">
<br /><br />
<input id="myRadios" type="radio" onclick="handle(this);"/>
</div>
Dinesh
</script>
<div id="abc">
<br /><br />
</div>
Dinesh
Author: Dinesh Kumar replied at 2024-07-30 09:20:22
Given some more inputs.
Expert: duncanb7 replied at 2024-07-30 09:14:23
Please write it in detail first that will assist other experts to easier or speed up answer your issue
Author: Dinesh Kumar replied at 2024-07-30 09:13:08
Hi Experts, I am on some deadline, if you can also help on following:
http://www.experts-exchange.com/Programming/Languages/Scripting/JavaScript/Q_28486990.html
Expert: duncanb7 replied at 2024-07-30 09:08:08
Thx for your pt
Author: Dinesh Kumar replied at 2024-07-30 09:04:00
using class with radio button worked otherwise I kept trying # instead of . in jquery and of no use.
Thanks everyone who helped me in reaching out solution.
Finally the solution is:
$(document).ready(function () {
$(".myRadios").bind("click", function () {
alert($(this).val());
alert($(this).closest("td").next("td").html());
alert($(this).closest("td").next("td").next("td").html());
$(".btncss").bind("click", function () {
</script>
<div id="abc">
<br />
<br />
<table id="tbl">
<tr>
<td>
<input class="myRadios" name="abc1" id="abc1" type="radio" value="1" /></td>
<td>11</td>
<%--<td>22</td>--%>
</tr>
<tr>
<td>
<input class="myRadios" name="abc1" id="abc1" type="radio" value="2" /></td>
<td>22</td>
<td>33</td>
</tr>
<tr>
<td>
<input class="myRadios" name="abc1" id="abc1" type="radio" value="3" /></td>
<td>33</td>
<td>44</td>
</tr>
<tr>
<td>
<input class="myRadios" name="abc1" id="abc1" type="radio" value="4" /></td>
<td>44</td>
<td>55</td>
</tr>
</table>
<input id="Button1" type="button" value="button" class="btncss" />
</div>
I will put another question for getting it done on button click now after some tries from my side if not worked.
</script>
<div id="abc">
<br />
<br />
<table id="tbl">
<tr>
<td>
<td>11</td>
<%--<td>22</td>--%>
</tr>
<tr>
<td>
<td>22</td>
<td>33</td>
</tr>
<tr>
<td>
<td>33</td>
<td>44</td>
</tr>
<tr>
<td>
<td>44</td>
<td>55</td>
</tr>
</table>
</div>
Expert: Ray Paseur replied at 2024-07-30 08:37:24
I think the original question was answered, so I'll sign off now. To clarify the following elements of the <input> control...
type= tells the browser what kind of control to render.
name= tells the browser what name to apply to the value in the resulting request (when the form is submitted)
class= gives the name of a non-unique selector for use with CSS style or other actions
id= gives the name of a unique selector for use with CSS style or other actions
When the request is sent (form is submitted) any unfired radio button or unchecked checkbox is absent from the request. This differs from inputs of type="text" where the input control is present in the request, but with an empty value. As a result it's important for the action script to know what possible names and values might be expected.
Expert: Ray Paseur replied at 2024-07-30 08:30:12
Going forward, please use the Code snippet feature when you post code here at E-E. It gives us line numbers and a unispace font that makes things easier to read and discuss. Just click the word Code in the line of formatting controls and paste your code between the tags.
Expert: Gary replied at 2024-07-30 08:16:44
150 points EXCELLENT
So the problem is nothing to do with your original code
Replace
alert($(this).next("td").html());
with
alert($(this).closest("td").next("td").html());//
http://jsfiddle.net/GaryC123/467Lp/3/
Replace
with
Author: Dinesh Kumar replied at 2024-07-30 08:14:20
Hi Ray, I am sorry but if you can give look on the following:
<script type="text/javascript"> $(document).ready(function () { $(".myRadios").bind("click", function () { alert($(this).val()); //alert($(this).find("td").eq(1).html()); //alert($(this).find("td").eq(2).html()); alert($(this).next("td").html());// THIS IS NOT WORKING }); }); </script> <div id="abc"> <br /> <br /> <table id="tbl"> <tr> <td> <input class="myRadios" name="abc1" id="abc1" type="radio" value="1" /></td> <td>11</td> </tr> <tr> <td> <input class="myRadios" name="abc1" id="abc1" type="radio" value="2" /></td> <td>22</td> </tr> <tr> <td> <input class="myRadios" name="abc1" id="abc1" type="radio" value="3" /></td> <td>33</td> </tr> <tr> <td> <input class="myRadios" name="abc1" id="abc1" type="radio" value="4" /></td> <td>44</td> </tr> </table> </div> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:
Expert: Ray Paseur replied at 2024-07-30 08:11:31
100 points EXCELLENT
See if this makes sense for your needs.
<!DOCTYPE html><html dir="ltr" lang="en-US"><head><meta charset="utf-8" /><meta name="robots" content="noindex, nofollow" /><meta name="viewport" content="width=device-width, initial-scale=1.0"><script type="text/javascript" src="http://code.jquery.com/jquery-latest.min.js"></script><script>$(document).ready(function (){ $(".myRadios").change(function(){ var radioValue = $(this).val(); alert('Radio: ' + radioValue); });});</script><title>HTML5 Page With Radio Buttons</title></head><body><div id="abc"> <input class="myRadios" name="abc1" id="radio1" type="radio" value="1" /> <input class="myRadios" name="abc1" id="radio2" type="radio" value="2" /> <input class="myRadios" name="abc1" id="radio3" type="radio" value="3" /> <input class="myRadios" name="abc1" id="radio4" type="radio" value="4" /></div></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:
Expert: Gary replied at 2024-07-30 07:56:36
Good catch by Ray
Don't know why everyone is insisting on using js to do what a radio group does naturally.
Well you have nothing in your radio buttons to identify anything, if you give them a value.
http://jsfiddle.net/GaryC123/467Lp/2/
Expert: duncanb7 replied at 2024-07-30 07:55:55
Try this
$(document).ready(function () { $(".myRadios").bind("click", function () { $('.myRadios').removeAttr('checked'); $(this).attr('checked', true); }); }); 1:2:3:4:5:6:7:8:9:
Expert: Ray Paseur replied at 2024-07-30 07:55:02
There can only be one id= attribute of a given name. With multiple id="abc1" input controls, the document may confuse the browser and so this probably will not work properly.
Author: Dinesh Kumar replied at 2024-07-30 07:51:53
Current code is: <script type="text/javascript">
$("#abc").find('input[type=radio]').not($(this)).prop('checked', false);
</script>
<div id="abc">
<br /><br />
<input class="myRadios" name="abc1" id="abc1" type="radio" value="3"/>
<input class="myRadios" name="abc1" id="abc1"type="radio" value="4" />
</div>
</script>
<div id="abc">
<br /><br />
</div>
Author: Dinesh Kumar replied at 2024-07-30 07:51:21
I am looking either in jquery or javascript, I want take some action when particular radio button is selected.
so looking for code which tells me which radio button is selected.
Expert: Ray Paseur replied at 2024-07-30 07:18:32
Unlike checkboxes, radio buttons are mutually exclusive by design.
http://www.utexas.edu/learn/forms/radio.html
Is there more to this question?
Expert: Gary replied at 2024-07-30 07:15:16
Just give the radio buttons the same name then they will unselect by default - no need for javascript
This is how you are supposed to use radio buttons.
Expert: duncanb7 replied at 2024-07-30 07:11:20
Dear Author,
-use your jquery library path and replace the one in the code
-use class for "myRadios" instead of id
-try this code for example only
<html><meta http-equiv="Content-Type" content="text/html; charset=Big5"><head><title>Title</title><style></style><script src="/js/jquery.min.js" type="text/javascript"></script><script src="/js/jquery-ui.min.js" type="text/javascript"></script><script type="text/javascript">$(document).ready(function() {});</script><script type="text/javascript"> function handle(myRadio) {console.log("testing"); // $('input[name=radioName]:checked').attr('checked', false); $('.myRadios').removeAttr('checked'); $(myRadio).attr('checked', true); }</script></head><body ><div id="abc"> <br /><br /> <input class="myRadios" type="radio" onclick="handle(this);"/> <input class="myRadios" type="radio" onclick="handle(this);"/> <input class="myRadios" type="radio" onclick="handle(this);"/> <input class="myRadios" type="radio" onclick="handle(this);"/></div></body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:
