When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rookaps
at 2024-07-30 03:06:19
Point:500 Replies:7 POST_ID:829164USER_ID:12049
Web Languages/Standards;Hypertext Markup Language (HTML);Cascading Style Sheets (CSS)
How can I center these 3 boxes within the div (with red border)?
http://rookaps.com/example.htm
Thanks.
Thanks.
Attachment:example.cssexample.htm
Author: rookaps replied at 2024-07-30 10:47:41
Expert: duncanb7 replied at 2024-07-30 10:27:23
Thx for your pt
have a nice day
have a nice day
Author: rookaps replied at 2024-07-30 10:11:37
I'm sure all of these work beautifully. I must admit I had just given up and reverted to a table.
Thanks.
Thanks.
Expert: COBOLdinosaur replied at 2024-07-30 10:11:12
You probably have an issue related to using position:absolute; and margin:auto If you want it centered then get rid of the position absolute and set the top position with a margin-top of 120px; then the text-align:center should finish the job.
The way the properties of the .absolute-center class are written you will have all kinds of cross-browser, and cross-device anomalies because you are giving the client contradictory instructions.
Cd&
Cd&
Expert: Gary replied at 2024-07-30 07:17:44
167 points EXCELLENT
Thanks.
Thanks.
Expert: duncanb7 replied at 2024-07-30 06:07:36
166 points EXCELLENT
Thanks.
Thanks.
Expert: Dexter_morgan replied at 2024-07-30 03:30:52
Hey there,
There exist many solutions to your problem, however i am attaching two approaches, you can refer to them as per your convince. I incorporated those 3 div to be centered in a separate class and there defined style for them, you group them and define them similarly too.
Feel free to revert back for further queries / doubts.
~Dex
~Dex
