When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by isdd2000
at 2024-07-30 01:17:20
Point:500 Replies:3 POST_ID:829161USER_ID:12054
MS SQL Server;IT Administration;Windows Server 2012
Hi Experts,
I have noticed my SQL 2012 server is running between 87-95% CPU usage. The environment is a Windows Server 2012 with SQL 2012 standard installed, the server is not used for anything else other than VPN occasionally. We only have one instance running and the CPU is a 3.4GHz Quad Core Xeon and task manager is reporting SQLSERVER using all the CPU.
I would like to identify where this is being used, weather there is a leak or it is legitimate and i need a secondary CPU.
Look forward to reading your solutions.
Author: isdd2000 replied at 2024-09-02 21:28:31
Issue ended up related to debug logging
Expert: Barry Cunney replied at 2024-07-30 01:40:10
Hi
You can use the following SQL to identify what exactly is running in SQL Server - this will give a picture of the workload being carried out in SQL server and may give some ideas on the CPU usage
SELECTHostname,nt_username,program_name,sp.login_time,qt.text AS [Parent Query],sp.cpu,sp.memusage,sp.physical_io,er.total_elapsed_time,session_Id AS [Spid],er.blocking_session_id,er.granted_query_memory,er.start_time,ecid,DB_NAME(sp.dbid) AS [Database],er.status,er.wait_resource,wait_type,SUBSTRING (qt.text, (er.statement_start_offset/2) + 1, --#1((CASE WHEN er.statement_end_offset = -1THEN LEN(CONVERT(NVARCHAR(MAX), qt.text)) * 2ELSE er.statement_end_offsetEND - er.statement_start_offset)/2) + 1) AS [Individual Query],nt_domainFROM sys.dm_exec_requests er --#2INNER JOIN sys.sysprocesses sp ON er.session_id = sp.spidCROSS APPLY sys.dm_exec_sql_text(er.sql_handle)as qtWHERE session_Id > 50AND session_Id NOT IN (@@SPID)ORDER BY sp.cpu DESC 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:
Expert: duncanb7 replied at 2024-07-30 01:32:55
You check the CPU usage from command of "taskmgr.exe" and click "resource monitor"
at the performance tab.
You could download the MS ProcessExplorer to look into more in detail at this
site to find which process is getting high cpu usage, http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
