When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by Thenkung
at 2024-07-30 00:26:05
Point:500 Replies:8 POST_ID:829160USER_ID:12051
Microsoft Operating Systems;Microsoft Windows Operating Systems;Windows 8
Expert: McKnife replied at 2024-07-31 23:35:36
Was it solved?
Author: Thenkung replied at 2024-07-31 18:28:25
Thank
Expert: McKnife replied at 2024-07-30 15:41:20
125 points EXCELLENT
I wonder why experts look at the application layer first...it looks more like a network performance problem.
If this is Gigabit, of course explorer would be much, much faster than 11 MB/s , that's around 100 Mbit/s.
So please use a network benchmark (netio) and see how it performs.
If that is no better, see if you can find a newer driver for your NIC.
Expert: Manjunath Sullad replied at 2024-07-30 03:45:10
You can try downloading Microsoft's application, RichCopy (This is replacement for RoboCopy if you are transferring large no of data over network.)
Download from : http://download.microsoft.com/download/f/d/0/fd05def7-68a1-4f71-8546-25c359cc0842//HoffmanUtilitySpotlight2009_04.exe
Refer : http://technet.microsoft.com/en-us/magazine/2009.04.utilityspotlight.aspx
http://social.technet.microsoft.com/Forums/windows/en-US/33971726-eeb7-4452-bebf-02ed6518743e/microsoft-richcopy
Expert: stevejacob68 replied at 2024-07-30 02:51:25
You can download teracopy software to increase the speed of copy and paste of file. Teracopy software comes with additional features as it allow user to pause and resume moving file.
To download teracopy software:
search for teracopy in google and there are number of websites that provide software for free downloading.
Expert: duncanb7 replied at 2024-07-30 01:42:18
Why you don't use robocopy ? there is option for allowing copy process in multi-thread mode to speed up the copy process
Please taka look at this article about robocopy at http://www.pcadvisor.co.uk/how-to/software/3427256/how-copy-paste-files-faster/
it is free.
it is free.
Author: Thenkung replied at 2024-07-30 01:10:47
Actually , I have to copy form my PC to another PC in the same local area network
provide connection by Cisco Catalyst Express 500G , 10/100/1000
Thank
Thank
Expert: PeteLong replied at 2024-07-30 00:29:37
at 11mbps Im guessing that you are copying to USB? In which case you are limited by the USB bus on your computer, and the USB device, if you want faster USB transfers fit a USB3 card and use a USB 3 Capable device.
