When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by rookaps
at 2024-07-29 21:00:06
Point:500 Replies:3 POST_ID:829158USER_ID:12049
Hypertext Markup Language (HTML);;Cascading Style Sheets (CSS)
I can not figure out why these will not align with my 'display:inline' css.
Help horizontally aligning this in the middle would be appreciated too.
Thanks!
http://www.rookaps.com/example
Thanks!
Attachment:example.htmexample.css
Expert: duncanb7 replied at 2024-07-29 23:39:35
you could clean up all html and css error first at free validator athttp://validator.w3.org/
Author: rookaps replied at 2024-07-29 23:31:35
Wow! If only, I could glue back all the hair I tore out.
Thanks,
Regards,
C. Terry
Thanks,
Regards,
C. Terry
Expert: duncanb7 replied at 2024-07-29 21:30:24
In your example, div tag is Not closing at item1, and now it works as you expect.
<!DOCTYPE html><html lang="en"> <head> <meta charset="utf-8"> <meta name="description" content=""> <meta name="keywords" content=""> <title></title> <style>.box1 { width:200px; height:200px; background-color:#09d2e7; display:inline; color:black; font-size:22px; } .box2 { width:200px; height:200px; background-color:#0fd207; display:inline; color:black; font-size:22px;animation-timing-function: } .box3 { width:200px; height:200px; background-color:#ffd2e7; display:inline; color:black; font-size:22px; }</style> </head> <body>Example:<br><br><br><div><div class="box1">Item 1</div><div class="box2">Item 2</div><div class="box3">Item 3</div> </div> </body></html> 1:2:3:4:5:6:7:8:9:10:11:12:13:14:15:16:17:18:19:20:21:22:23:24:25:26:27:28:29:30:31:32:33:34:35:36:37:38:39:40:41:42:43:44:45:46:47:48:49:50:51:52:53:54:55:
