When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by chima
at 2024-07-29 14:25:07
Point:500 Replies:7 POST_ID:829154USER_ID:12046
Hello,
This is so strange and I can't see what the problem is. I am sure it has a very simple solution.
And the cell format is the same.
Column J does not want to show the TRUE or FALSE, as does I;
Expert: duncanb7 replied at 2024-07-30 09:43:05
Thx for your ot
Author: chima replied at 2024-07-30 09:42:17
Author: chima replied at 2024-07-30 08:16:36
Hello everyone, while duncanb7's solution worked in one column, for whatever the reason does not work on other columns. I have looked at all of the cell's formatting and this does not solve the problem totally.
To add more clarification to the origin of this problem; the content of this Excel file comes from the conversion of a pdf to txt, then opened with Excel to form the xlsx file. I suspect that through all of the conversions the content got corrupt.
This issue is not all that important for me solve at this time, so I am tabling the problem, but issuing the points shortly.
Thank you all for the help.
Expert: Glenn Ray replied at 2024-07-30 00:02:52
200 points EXCELLENT
@Duncan,
If there was an error in either A1 or K1, that error would display in J1 (where this formula is).
It HAS to be that the cell is formatted as Text OR "Show Formulas" is turned on (not likely).
Expert: duncanb7 replied at 2024-07-29 22:33:22
probably is issue at A1 and k1 that let comparsion result will return to Null
You can try =ISERROR(IF(A1=K1,TRUE,FALSE)), it will prove it if return to True from iserror()
A1 may have this #value or K1 may have this #DIV something like that
Expert: Glenn Ray replied at 2024-07-29 15:17:09
Column J is probably formatted as Text; change the cell(s) or entire column to "General" then press [F2] and [Enter] on that first cell in J1.
-Glenn
-Glenn
Expert: itjockey replied at 2024-07-29 14:34:13
100 points EXCELLENT
One shortcut solution - Delete column J - Add new column. So if any formatting issue.Then it will be resolved .
