When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by jskfan
at 2024-07-29 07:46:58
Point:500 Replies:10 POST_ID:829152USER_ID:11761
Windows Server 2012;;Windows Networking
I ran IPConfig command ,and it shows 2 Different IP address:
192.168.50.129
192.168.50.160
However I have one Ethernet Network connection for 192.168.50.160.
Any idea where the 192.168.50.160 is coming from ?
192.168.50.160
Author: jskfan replied at 2024-07-29 17:47:09
Author: jskfan replied at 2024-07-29 13:17:36
As I said , Ipconfig /release and Ipconfig /renew fixed it....
Expert: duncanb7 replied at 2024-07-29 09:34:42
100 points EXCELLENT
what you did to let it back to normal ? If not, it might NOT solve this issue (please try command of "ipconfig" only without all)
Author: jskfan replied at 2024-07-29 09:27:17
Ipconfig is showing normal config now:
Expert: duncanb7 replied at 2024-07-29 09:16:24
Could you send us output command of "ipconfig /all" ?
Probably, on your vm setup and it assigned multiple IPs, NIC can have more than 1 IP.
Why not just delete the multiple IP with the followng command for reseting WinSock and TCP/IP,
and reboot computer, and then reconfigure your IP setting ?
netsh winsock reset catalog
netsh int ip reset reset.log
Hope understand your question completely.If not, pls pt it out
Author: jskfan replied at 2024-07-29 09:01:15
Some unknown thing was acting up I guess...
I fixed it with IPCONFIG/Release then IPCONFIG/Renew
Expert: tolinrome replied at 2024-07-29 08:17:38
if youre using another workstation on your laptop, does that nic have the .160 assigned to it then?
Author: jskfan replied at 2024-07-29 08:13:36
checked the advanced settings, no 160 there, just 129
I am using VMware workstation on my laptop, I do not think I need DHCP
Expert: perolin replied at 2024-07-29 08:09:59
An better then static setting … use DHCP for IP Configuration, “obtain an IP address automatically”. It makes life easy. DHCP is running on almost every Router or other network device. If you do want to keep it static, make a reservation on DHCP server or push the lease time to 0.
Expert: tolinrome replied at 2024-07-29 07:48:09
if you go to advanced settings you'll probably see the IP address added to the NIC.
