When upgrade gcc or lib, it will cause issue, and may cause reboot is not working for exmaple: https://blog.csdn.net/qq_39295044/article/details/86685789 su root Password: node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) nvm is not compatible with the npm config "prefix" option: currently set to "" Run `nvm use --delete-prefix v16.20.2 --silent` to unset it. For example, running ------------------- node node: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) Or php php: /lib64/libc.so.6: version `GLIBC_2.18' not found (required by /lib64/libstdc++.so.6) after re-install glibc at /usr/local and run nvm use --delete-prefix v16.20.2 --silent` //for node other issue now ok, php and node but got some error when install python3.9 version rm -f /usr/local/glibc-2.18/build/stubs.h /usr/local/glibc-2.18/build/elf/sln /usr/local/glibc-2.18/build/elf/symlink.list rm -f /usr/local/glibc-2.18/build/elf/symlink.list test ! -x /usr/local/glibc-2.18/build/elf/ldconfig || LC_ALL=C LANGUAGE=C \ /usr/local/glibc-2.18/build/elf/ldconfig \ /lib64 /usr/lib64 LD_SO=ld-linux-x86-64.so.2 CC="gcc -B/usr/bin/" /usr/bin/perl scripts/test-insta llation.pl /usr/local/glibc-2.18/build/ /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtod_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof128_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtof_nan@GLIBC_PRIVATE' /usr/lib/gcc/x86_64-redhat-linux/4.8.5/../../../../lib64/libm.so: undefined refe rence to `__strtold_nan@GLIBC_PRIVATE' collect2: error: ld returned 1 exit status Execution of gcc -B/usr/bin/ failed! The script has found some problems with your installation! Please read the FAQ and the README file and check the following: - Did you change the gcc specs file (necessary after upgrading from Linux libc5)? - Are there any symbolic links of the form libXXX.so to old libraries? Links like libm.so -> libm.so.5 (where libm.so.5 is an old library) are wrong, libm.so should point to the newly installed glibc file - and there should be only one such link (check e.g. /lib and /usr/lib) You should restart this script from your build directory after you've fixed all problems! Btw. the script doesn't work if you're installing GNU libc not as your primary library! make[1]: *** [install] Error 1 make[1]: Leaving directory `/usr/local/glibc-2.18' make: *** [install] Error 2 Change libm.so link to 2.18 version Make sure glibc, libc.so libm.so is same version
Asked by AndreasHermle
at 2024-07-28 23:56:25
Point:500 Replies:3 POST_ID:829150USER_ID:12043
Dear Experts:
I got thousands of entries in Column A. Part of the string in these entries can be 99-999-99-99 such as ...
P:\Graphics\MyFolder\99\99-999-99-99.tif
I would like a macro ...
... to count the number of entries in Column A in the current worksheet where the sub-string 99-999-99-99 occurs.
The result is to be displayed in D5 of the current worksheet.
Help is much appreciated. Thank you very much in advance.
Regards, Andreas
Regards, Andreas
Author: AndreasHermle replied at 2024-07-29 04:06:20
Dear both,
both codes / formulas work just fine. I suggest splitting the points 350:150
Thank you very much for your great and swift support. I really appreciate it. Regards, Andreas
Expert: duncanb7 replied at 2024-07-29 00:30:32
350 points EXCELLENT
it should be
=CountIf(A:A, "*" & "99-999-99-99" & "*")
you can try this macro
Sub test()ActiveSheet.ActivateDim str As Stringstr = "99-999-99-99"ActiveSheet.Range("D5") = Application.WorksheetFunction.CountIf(ActiveSheet.Range("A:A"), "*" & str & "*")ActiveSheet.Range("D5").SelectEnd Sub 1:2:3:4:5:6:7:
Expert: krishnakrkc replied at 2024-07-29 00:11:27
150 points EXCELLENT
Hi
Do you really need a macro for this ?
=COUNTIF(A:A,"*99-999-99-99*")
would suffice.
Kris
would suffice.
Kris
